Old 01-26-2008, 10:58 PM   #1
blazer bill
plastic gas tank
I Pulled My Gas Tank Off And It Had Quite A Bit Of Rust In It. Most Of The Places I`ve Been Looking For A Replacement Are Metal Has Anyone Seen A Replacement Thats Plastic.
blazer bill is offline   Reply With Quote
Old 01-26-2008, 11:32 PM   #2
Burt4x4
Burt4x4's Avatar
Re: plastic gas tank
Yup, there is a Polyethelane (sp?) tank made that is a direct replacement. You do have to extend the filler hose because the neck on the poly tank is much shorted than the metal one.
What I did was cut off the metal filler neck, then cut the rubber filler hose in half and put the metal neck into the rubber hose to make it longer.
I think I got mine from brotherstrucks.com
I don't have the tank anymore as I upgraded to a 37gal tank from North West Metal Products.
I ran the plastic one for about 2yrs and the only problem I had was the sending unit's rubber seal or O-ring would let gas out when I filled the tank to the top, gas would drip out the top until the level droped..a new o-ring probly would have fixed that....
Good Luck
Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-27-2008, 12:48 AM   #3
Frizzle Fry
Frizzle Fry's Avatar
I have on in my Burb (same as Blazer) and I had the same leak. I fixed it by bending the tabs on the lock ring down a little bit to provide more sealing pressure. Otherwise no issues.
Frizzle Fry is offline   Reply With Quote
Old 01-27-2008, 07:55 AM   #4
Long Roof
Old School, New Style
Long Roof's Avatar
I have the plastic tank also and same leak here. Seems ok if I stop filling after the nozzle cut off but if I try to top it off then it leaks.
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 01-27-2008, 11:01 AM   #5
blazer bill
With the price of gas now days I don`t think I`ll be filling my tank full.
