Old 01-27-2008, 09:49 AM   #1
hotrodhomi
hotrodhomi's Avatar
Panhard question
I’m in the process of plumbing my air bags on my ’72 blazer and I noticed that when its layed out the rear end is not centered. It’s much closer on the driver’s side. Will a shorter panhard bar correct this? If so, how do I know which one to buy?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 01-27-2008, 11:06 AM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Panhard question
you need an adjustable one. available thru most vendors.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-27-2008, 11:48 AM   #3
jlaird
jlaird's Avatar
Correct me if i'm wrong, but you want a longer bar, not a shorter one. The longer it is, the less movement you will get. Also, don't worry if your rearend is not centered when you're laid out. It shouldn't be. It should be setup so your all centered at ride height. Then as you move up or down from your ride height, you will get movement from center.
jlaird is offline   Reply With Quote
Old 01-27-2008, 11:51 AM   #4
hotrodhomi
hotrodhomi's Avatar
I looked up bars at Summit and a saw that they had about a dozen choices from $85 to $200. Any recommendations?
'66 impala ht
Old 01-27-2008, 11:57 AM   #5
hotrodhomi
hotrodhomi's Avatar
It's a little off at ride height, but it makes my tire kiss the inside of my fender when aired out.
'66 impala ht
Old 01-27-2008, 12:16 PM   #6
jlaird
jlaird's Avatar
are you looking for a weld on or bolt on application?
Old 01-27-2008, 12:20 PM   #7
jlaird
jlaird's Avatar
for bolt on, I would recommend to go to earlyclassic.com and check out the super track bar.
Old 01-28-2008, 02:42 AM   #8
LONGHAIR
What you really need is a "Watts link". A panhard bar will always be off-center at some point in the suspension travel of a 'bagged vehicle. You can get an adjustable bar, but that only lets you decide "where" it is right. The more travel you have in your suspension, the greater the effect.
A sliding, wish-bone type 3rd link will work too. It depends upon your fab skills and the available space under your truck, but you could do either.
LONGHAIR is offline   Reply With Quote
Old 01-28-2008, 03:10 AM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
ECE... all the way!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-28-2008, 06:43 AM   #10
hotrodhomi
hotrodhomi's Avatar
I'm not sure a watts link would work with my gas tank in the middle.
'66 impala ht
Old 01-28-2008, 07:21 AM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
I'm surprised it's closer on the driver's side when "air'd out". I would think it would shift to the passenger side. Try the Super Track Bar from ECE. It's longer than the stock bar (for less movement),... and is a bolt on. But you will still get movement. And the reaseon it's longer,... is because it attaches to the passenger side trailing arm.
Keith
Convert to disc brakes.
Old 01-28-2008, 11:51 AM   #12
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I agree...the watts IS the way to go....
Here is what a basic one looks like....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 01-28-2008, 01:24 PM   #13
Slmd92DIME
Slmd92DIME's Avatar
I am seriously rethinkin the panhard in mine. I am leaning towards the watts also.
Slmd92DIME is offline   Reply With Quote
Old 01-28-2008, 01:42 PM   #14
hotrodhomi
hotrodhomi's Avatar
Does anyone sell a kit for these or would I need to fab everything myself?
'66 impala ht
Old 01-28-2008, 05:50 PM   #15
GMBowtie79
Surviving, one day at a time!
GMBowtie79's Avatar
Check out KPComponants.com they might have one for your application.
GMBowtie79 is offline   Reply With Quote
Old 01-29-2008, 12:04 AM   #16
LONGHAIR
If it will not fit, you can go with the sliding wishbone, in the front of the axle.
Old 01-29-2008, 02:06 AM   #17
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I had to fab-up this one because my customer had me install this massive 14-bolt into his truck....
Kp does make a 12-bolt kit...it's like $400..nice piece
This 67 has an aluminum rear tank...and it fits PERFECT.....
Click on the build link to see more pics
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 01-29-2008, 06:35 AM   #18
Slmd92DIME
Slmd92DIME's Avatar
www.speedwaymotors has one for like 70 bucks. It goes off the top of the axle. You could make your own diff. bracket though.
Old 01-29-2008, 09:28 AM   #19
GMBowtie79
GMBowtie79's Avatar
That one from speedway might be goot on a 9" I dont know about mounting that top bracket on GM diff where the center section is cast. I'd take some mesurements and call KP to see if it would fit, Clint seems to know his s#!t.
