Old 01-27-2008, 10:30 AM   #1
old_blew_72
old_blew_72's Avatar
upper a-arm air bag plate/mount question
i'm wanting to bag the front of my c-20. last year i put bags on the trailing arms but kept stock ride height, i wanted it to pull good and be able to load it heavy and not have it ride like a c20 if you know what i mean. i built the trailing arms and bag mounts and i figured since i've got plumbing to two bags what's two more. anyway i'm looking for something like this, i think it's pretty popular, but i want to build it myself.
old_blew_72 is offline   Reply With Quote
Old 01-28-2008, 03:13 AM   #2
TravisH
TravisH's Avatar
Re: upper a-arm air bag plate/mount question
So what is the question? That plates not hard to make but like with most pieces from suicidedoors I found it cheaper to buy than to spend time setting up
TravisH is offline   Reply With Quote
Old 01-28-2008, 04:28 AM   #3
old_blew_72
oh duh i guess i wanted to know the bag style or number that should be used on this front setup w/ all stock a-arms/ spindles.
Old 01-28-2008, 04:58 AM   #4
TravisH
TravisH's Avatar
The size will depend on your rear setup some to get the stance you're after
I'd recommend a slam specialties RE6. They work great for front suspension because they've got an integrated bump stop which is really convenient. I'd also recommend you got with some drop spindles, even with this bag you might be higher than you want.
