01-27-2008, 10:57 AM | #1 |
problem hooking up gauges on my bagged truck
What type of fittings did you use to hook up your air pressure gauges on your bagged truck? I wanted to get a t fitting with two 3/8 ports and one 1/8 port, but I cant find any. Im trying to read the pressure on my 3/8 lines and my gauge has two 1/8 male npt fittings. I wanted to run 1/8 line to the gauges because I was going to put them in my dash and I wanted something flexible.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
01-27-2008, 12:25 PM | #2 |
Re: problem hooking up gauges on my bagged truck
I know ART & SuicideDoors both offer 1/4" to 1/8" PTC 'T' fittings; not sure about 3/8" to 1/8".
You might need to reduce your 3/8" line w/readily available reducers & then reduce the line size again for the 1/8" stuff if there's not a direct 3/8" to 1/8" reducer.
01-27-2008, 01:41 PM | #3 |
Thats what I was afraid of. I was trying to get away with less fittings. Cleaner look, you know?
01-28-2008, 06:17 AM | #4 |
Drill and tap an existing fitting. I've got a 3/8" npt t immediately after a fill valve, one end goes to the bag and the other goes to dump valve. Drilled and tapped a fitting in the side of it for my gauges
01-28-2008, 08:56 AM | #5 |
A guy with a truck
This what I bought: https://www.*****************/Fitting...ugeFitting.php
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) 07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-28-2008, 11:35 AM | #6 | |
Hollister, CA.
I was just gonna say that...that is what I did for the 67.....this was for a scharder thought....1/8 pipe is all you need... - - -
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
