Old 01-27-2008, 03:45 PM   #1
r8edx2000
Corvette 700r4
I have the option to get a 700r4 for free from a 86 c4 vette. Is this transmission worth rebuilding? One more question how much can I get for the suspension parts off of the vette? Thanks in advance.
r8edx2000 is offline   Reply With Quote
Old 01-27-2008, 03:48 PM   #2
Mister laugh
Re: Corvette 700r4
If your after a 700r4 the corvette ones are the ones your after. I would say it's worth it if it's what you want.
Mister laugh is offline   Reply With Quote
Old 01-27-2008, 07:00 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
Re: Corvette 700r4
Please let me know if you are not going to use it. I've been thinking about switching my turbo 350 over to a 700r4.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 01-27-2008, 10:25 PM   #4
see ten
WTB this ad
see ten's Avatar
Re: Corvette 700r4
Corvettes and 5.7 camaros and I assume T/As have pretty much the same trans don't they? I do know that they are different in the fact that they have the ability to stay in overdrive at wide open throttle. Other 700R transmissions will kick in and out of O/D. It seems that the valve bady is different.
see ten is offline   Reply With Quote
Old 01-27-2008, 11:15 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Corvette 700r4
700R4'S built after 84 I believe are the good ones anything earlier and it will need some work to handle any real power. I could be wrong on the year break though..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-27-2008, 11:30 PM   #6
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
Re: Corvette 700r4
The ones built after 87 are the best ones. They have the 10 vane pump, better input shaft & beefed up internals. The mid 80's are the no-horsepower years, & hence they didnt need to make the trans very beefy either. If you are going to get it rebuilt anyway, then the 86 is fine because they will update it with the newest guts anyway. If you are going to drive it, then get at least an 87 or up. I blew up my origional from an 85 Camaro & it lasted 6 months. I traded it for a rebuilt one from a 91 Suburban & it lasted 13 years under my heavy foot. I just found a good description here:
http://en.wikipedia.org/wiki/Turbo-H...al_Description
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 01-28-2008, 01:17 AM   #7
whatnow123
whatnow123's Avatar
Re: Corvette 700r4
Anyone know how to tell the difference in years of the trans without removing it? I know about the input shaft, but seems like a lot of work just to check.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 01-28-2008, 01:40 AM   #8
passthebuck
Re: Corvette 700r4
There is a serial number on the side of the pan rail. Also, the newer pump has a certain casting number - you need to pull the torque conver to id that.
http://www.hotrodders.com/articles/T...ification.html
http://purplesagetradingpost.com/sum...o/700R4p1.html
http://links.chevelles.net/links/Wor...l_Auto_Tranny/
http://www.geocities.com/crosley_az/4l80e.htm
http://www.geocities.com/crosley_az/700id.htm
http://www.hotrodders.com/forum/chev...R4+Information
passthebuck
#5642
Old 01-28-2008, 02:05 AM   #9
r8edx2000
Re: Corvette 700r4
Thanks guys. Anybody know how much it would cost to rebuild the 700r4 in the San Francisco bay area.
Old 01-28-2008, 02:29 AM   #10
passthebuck
Re: Corvette 700r4
Expect to pay around 1600 for 450hp & 2600 for 800hp. I'm not sure what they'll give you for your core though. If my memory serves, the Corvette 700r4's of that era dont have the conventional mounting pad on the tail shaft housing. It' an easy swap to a normal tailhousing though.
passthebuck
#5642
Old 01-28-2008, 02:32 AM   #11
whatnow123
whatnow123's Avatar
Re: Corvette 700r4
That's awesome! Thanks!
Build thread:
Old 01-28-2008, 11:36 AM   #12
68K20 x Drill
Re: Corvette 700r4
On mine I just put a TH400 mount front to back instead of cross ways like a normal car.
I did to make my own crossmember for other reasons.
Last set of 'vette suspensions I had went fairly quick for $750.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs.
84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80
68 GMC C20 Parts? Truck
And a few cars
68K20 x Drill is offline   Reply With Quote
