01-27-2008, 11:46 PM | #1 |
TQ Converter Recommendation
Alrighty, in case you all didn't see, I picked up a used TCI 700r4 and converter this week. The converter is a 3000 stall which I think is way to high for my truck (mild 350). What range stall should I be looking at? I was thinking 2200 or 2400.
Also, if anybody knows a vendor where I can pick one up at a reasonable price, I'd appreciate it. |
01-28-2008, 01:44 AM | #2 |
Re: TQ Converter Recommendation
I would try it. My buddy owns a tranny shop and told me that those converters are always lower then they are speced at.
01-28-2008, 04:50 AM | #3 |
Junior Member
Don't know if you would be interested. Spec rite builds a great torque converter.
http://www.racingjunk.com/post/10252...Spec-Rite.html
1970 C10 Short fleet side. For sale http://cgi.ebay.com/ebaymotors/ws/eB...MESE:IT&ih=017 |
01-28-2008, 05:02 AM | #4 |
its all about the +6 inches
call TCI or the other converter companys, they have tech lines specificly for this problem.
Converters aren't always lower than rated, it all depends on the torque curve, and output, of the engine. You'll need your engine CID, cam info, vehicle weight, lock up or non, tranny type, rear gears, cruise RPM, tire size, and specific vehicle use. |
01-28-2008, 06:54 AM | #5 |
Thanks Longhorn, I went to TCI's website and they have an online form you can fill out for a TQ recommendation. So I filled it out and hopefully they'll get back to me. If not, I'll give them a call.
01-28-2008, 07:02 AM | #6 | |
That being said the 3000 rpm stall you have should be perfect for a mild 350. It will stall at about 2400 and will not slip in normal traffic.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
01-29-2008, 06:50 AM | #7 |
Thanks bigjim! That's good to hear, I was worried it might be a little too high...
