Old 01-28-2008, 12:36 AM   #1
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
drip edge sealing
I need to re-seal the cab because the sealant at the drip edge is cracked and falling out. Should I use seam sealer or something else?
Which one looks like the one anyone has used for this spot?
http://solutions.3m.com/wps/portal/3...be6DTWTJQPBBgl
Thanks!
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 01-28-2008, 01:08 AM   #2
Rust Buster
Rust Buster's Avatar
Re: drip edge sealing
Go for the 3m Automix #8308, it's very good stuff, but you do need a special gun. There is also a self leveling version that might be good for this.
Maj USAF
71 K5 Blazer CST
72 K20 HT383 NV4500 Mass-Flo EFI
71 K10 LWB
52 Dodge Power Wagon
67 Dodge WM300 Power Wagon
48 Dodge WDX Power Wagon
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=239487
Rust Buster is offline   Reply With Quote
Old 01-28-2008, 01:33 AM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Thumbs up Re: drip edge sealing
Yes the 3M automix is the only way to go, it is what all of the body shops around here use. It won't shrink or crack either.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 01-29-2008, 12:14 AM   #4
Old Chevy Mech
Keepin it runnin!
Ok..I am not seeing this at the 3m site..I dont doubt it does but not using those numbers. Is it at this site?
http://www.sherwin-automotive.com/pr...cts.cfm?cat=74
Sorry to be a pain..
Frank
1970 K-5 4X4 Blazer
Old 01-29-2008, 01:29 AM   #5
Firefighter
Ok maybe this will help.
Most every store that carries 3M will use the number at the right hand corner.
So the Heavy bodied sealer is 3M #08308
The self leveling is 3M #08307
And the applicator gun is 3M #08571.
Now these products are not cheap, but they are the best out there.
The seam sealers are around $35.00 a tube and the applicator gun is around $55.00, kinda pricey
but if you look at it the way I did it's a heck of alot cheaper than having rust cut out and new panels welded in!!!
These products were recommended by a buddy of mine that has an autobody shop this is all they ever use and have for the past 10 yrs, I have seen some of the cars and trucks that they have done years ago and it still looks the same as when they put it on.
Yellville, Ar. USA
Old 01-29-2008, 03:05 AM   #6
Rust Buster
Try ebay. I just bought the seam sealer for $26 each, and the gun for $49.
Maj USAF
71 K5 Blazer CST
71 K10 LWB
My Build Thread
Old 01-29-2008, 07:58 AM   #7
Old Chevy Mech
Keepin it runnin!
Thanks guys, I now know what my plan of attack and with what will be!
Frank
1970 K-5 4X4 Blazer
Old 01-29-2008, 09:44 AM   #8
Firefighter
No problem, anytime!!!!
Yellville, Ar. USA
Old 09-28-2008, 12:53 PM   #9
Brad
Out of the carpool lane.
Brad's Avatar
Digging up an old thread, but does anyone have a cheaper way to do this for a truck that will be sold. Mine needs to be done, but I can't justify a $90 cost on this. Anyone in the Northwest have this gun?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 09-28-2008, 03:05 PM   #10
Yep!That stuff is not the "only" way to go.I used another 3M product that I got at my Napa store the goes right into a normal caulk gun,is a fraction of the cost,and has been holding up just fine.It does what it was made to do and that`s all I wanted.f someone has had a bad experience I`d like to know.But,it seams* ok so far.It`s 3M Flexiclear Body Seam Sealer part #08405.
*pun intended
Old 09-28-2008, 03:44 PM   #11
Shyguy
Junior Member
Shyguy's Avatar
My son uses the black windshield sealer that is in a tube and applies it with a caulking gun.
It is paintable and seems to work out ok so far.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-28-2008, 03:49 PM   #12
brendonak
does someone have a pic of what this 3m stuff looks like on our trucks?
brendonak is offline   Reply With Quote
Old 09-28-2008, 09:48 PM   #13
463
463's Avatar
i just used the standard drip or seam sealer in the regular calking gun. cost $8.00 to $10.00. use gloves to finger fit to my liking - let dry prime & paint:
Trueman
463 is offline   Reply With Quote
Old 09-28-2008, 10:08 PM   #14
Ace in the hole
I'll add 3m ultrapro urethane to the list. Really good stuff and reasonable price. It should be used with a special gun too but I just taped of everything real good, 2" tape minimum, and poked a small hole in the foil pack and spread it with my finger. Worked great but man is it sticky.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 09-29-2008, 12:03 AM   #15
chevymad
I havent tried it yet. But the local auto paint store sold me a 3m product called Drip Check. It says on it that its made for this exact purpose. Comes in a regular squeeze tube for about $15.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 09-29-2008, 03:08 AM   #16
brendonak
Thanks for the pic
Can you paint over it?
Old 09-29-2008, 05:36 AM   #17
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Arrow Re: drip edge sealing
I had problems with this in the drip rail area for year's , the eastwood company sell's a sealer it is black when you put it on it's single stage and can be sanded and painted after 24 hour's it is the best I have ever used and the best I remember it was cheap too ,,,,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
