Old 01-28-2008, 01:58 AM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You have too much HP when....
........you break something!!
I can't wait to drive this new beast.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-28-2008, 02:48 AM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: You have too much HP when....
Or you found the weak link
Malo83 is offline   Reply With Quote
Old 01-28-2008, 06:19 AM   #3
f.monroe
f.monroe's Avatar
You can never have too much HP , just not enough ability to use it . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 01-28-2008, 07:10 AM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
So you did the 700r4 let loose or you just wanted to upgrade/refresh?
MylilBowTie is offline   Reply With Quote
Old 01-28-2008, 11:26 AM   #5
gchemist
gchemist's Avatar
Upgrade really, the 1800 stall converter was too low for the ZZ4. The previous rebuild would lock the converter in 3rd. Even in 3rd the motor bogged down too much. A new 2500 RPM stall should do the trick.
The 3-4 clutches and band were burned up. I have a nice reminder down the street. Tire marks will be there for months!
I can't wait to try the full throttle 3-4 upshift. The option was available on police and some performance cars. The new hard parts should hold up to 600 ft/lbs of torque. All the shifts will be positive and firm. I'm waiting for an Edelbrock bracket for the TV cable. I did not run one before, but this time I will. Don't want to be set back again.
The rebuild is a level 4 Raptor. http://www.transmissioncenter.net/700MegaRaptor.htm
The previous rebuild had some updated parts so the costs could have been higher. This time, 12 months or 12,000 miles because it should hold. The tranny guy says I'll be smiling ear to ear.
Notice the large cover on the servors? Both the servors were upgraded. The Corvette servo was replaced with a larger one. The only thing missing is a Vette govenor. I have one ready to put in. I'll wait to see how the stock one holds up. If shifts are under 5000 RPMs, the Vette governor goes in.
Old 01-29-2008, 05:48 AM   #6
Thumpin455
My truck is an alcoholic
Thumpin455's Avatar
You can never have too much power...
I wont tell you what it cost me to upgrade the 4L60E in my 98 Formula, everything on that page except the planetary set, mainly because mine was in good shape and it isnt in a heavy truck. Building your own has its advantages, but you only have yourself to blame when it breaks or doesnt work right...
Too much stuff, too many projects to list everything.
my 454 urged 76 swb beater
Thumpin455 is offline   Reply With Quote
Old 01-30-2008, 10:31 AM   #7
gchemist
gchemist's Avatar
I drove a 355 HP formula that had a similiar build 4L60E. The tranny was awsome in such a light car. The rear would nearly break loose on all shifts.
