Your opinion on ART arms
Hey guys, please let me know your opnions and experiences on ART arms. Are they worth it? For what do they help, alignment, drop, space?
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Your opinion on ART arms
I love mine the look great fit great and I dont think that you could rebuild and paint your old ones for what the art ones offer in convience and price.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
True Addiction
I feel that they are of great quality. They are a wee bit pricey, but are worth the Buck. I believe they do correct the geometry for getting really low. If you get them, better go ahead and order a PorterBuilt dropmember. Good Luck
#4 | |
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
I have the uppers because after spending the money to rebuild stockers, I spent a little more and got ART uppers. As a bonus, they help correct geometry. The lowers on the other hand are a different story. I have yet to bring myself to spend the money on them for basically looks. They really don't offer any advantage over the stockers except in the looks department. The only thing they really offer is you probably can get about an inch lower vs. using 1.5 tall cups. Don't get me wrong, I want the lowers REALLY bad, but they are overpriced IMO. I've been keeping my eye out for a used set, but that is like finding a needle in a haystack.
Are the ART arms only for bags? I know CPP makes a set for springs.
Semper Fi |
the lowers arm are(unless modified), the uppers i would think you could you them with springs.
Thank you for your replies. But I am still uncertain if I should buy them or not. Another point is that I wouldn't be able to use my sway bar which gives better ride quality.
I rebuilt my front end complete last year but badly hit with the lower a- arm on the driver side. So I have to replace him anyway. Better geometry and a gain in lowering are great but also a lot of bucks for it. Does anybody have pics of the clearance under the lower arm with 2.5" spindles and 3/4" cups? |
if you have to replace one or both because of damage, I would get the ART arms. Being in Germany though, shipping can be spendy.
why cant you run a sway bar? you just cant run a stock one. i think they sell a different one to go on there. i cant justify buying those either.
I just installed upper and lower arms. The installation was easy and the fit was perfect. They also make a "muscle bar" sway bar that is a direct bolt on to the lower arms, which is also made to correct the geometry of the sway bar when lowered.
We run the upper and lower strong arms and the fit was great. I am very happy with them and would recommend them. They look very clean.
http://streetbeatcustoms.com 1-800-420-5060 toll free order line Air Ride Headquarters |
#13 |
will they except an 8 inch bag? if so, ill be ordering a set tomorrow.
Build thread:http://www.67-72chevytrucks.com/vboa...d.php?t=663953 Instagram: Whytry85 |
#14 |
Where is the best place to buy ART stuff?
Semper Fi |
#15 |
Yes they should, i have 2b7 airlifts and have room around mine.
#16 |
Junior Member
The reason we dont build them to accept the factory sway bar is beacuase the factory bar is a clam shell mount design on the arm. As soon as you take the truck out of its original OE ride height spec it does not work right. Ours change it over to a modern end link.......
