Rolling Chassis - Frames
69 LWB 1/2 2WD Leaf 6 Bolt lug frame, rear and front suspension. Light to moderate surface rust, straight. $175
67 SWB 1/2 2WD Coil - 6 bolt lug frame, suspension and rear. Painted 70% but it has been hit and was not straightened correctly. Is the way I received it. Plan to pull A arms etc, some crossmembers and send it to the crusher. Swing arms are junk. $ 100 69 Nevada 3/4T 2WD, coils with leaf overloads, is a 350 465 4 speed. Truck has been here for 2 years, has light surface rust. Hate to send it to scrap yard but price for scrap is up. May consider some "parting" out of pieces. Would prefer to sell as whole. $200 As always, they are all asking prices, and subject to what you might need. I hate to scrap straight parts so the 67 is the first candidate for the yard. I plan to bust the front suspension apart and check the other crossmembers and perches etc for worthy of the time to remove. These rear axles are also available 1/2 340 front and rear for 4wd, rear had an axle tube welded. $100 each 1/2 340 10 bolt 2wd open $75 Dually Dana 70 3:73 open out of 1 Ton box van $275 1/2 swing arm from 71 open 308 $75 Email Post or PM for details or pics. I will try to pull some pics and post tomorrow. LILREDGMC Delivery may be possible west to Indiana, Louisville, Cincinnati, or east to Williamport areas when I head to those places. |
![]() Join Date: Feb 2005
Re: Rolling Chassis - Frames
do you have a rear coil spring set up? i need both trailing ares,1/2 ton coils,cross member w/mounting brackets,.i'm putting in old 54 trk.
The Nevada frame is a swing unit. I could cannibalize all the parts you want for your setup, and save the springs from the 1/2 shorty, or see if I still have another 1/2 ton set from a long bed. I'd like to see if anyone wants the whole deal, but from previous deals I haven't had much interest in frames even though they may be decent. I have a 71-72 1/2 swing, with no arms, so I could cut that one up for the parts you want. The swings were sold from it last year, and the front had been hit lightly, but it pooched the rails just before the firewall. I need to look at that and get pictures for you, and you need to let me know if you have preferences on how much of the attachments you need. Let me know what you think.
LILREDGMC |
#4 | |
Paint, Body & Metalworker
![]() Join Date: Jan 2008
![]() Join Date: May 2007
Can you post pics of the 3/4 ton frame.
James
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
PICS of 3/4 and 1/2 shorty
1/2 ton and 3/4 overload
DD
New you had the idea but I was not complete with the description. There is a huge weld where they spliced a front rail, but they failed to straighten much along the way. 51-68 We can get you what you want, first may be how soon you need it, second to work out may be what you get. The 1/2 from CO should have what you want less trailing arms, those I could take from the 3/4. That would leave the 3/4 only minus trailing arms and the CO frame which has the light hit in the front used for your project. I think I understand it, how about you? LILREDGMC |
51-68
I can get you a crossmember, springs, but the trailing arms may have to wait as I am out of town to KC for 2 weeks. I can grind the rivets for the crossmember, and pull the springs from the 1/2 ton. How soon did you want the parts. Dually Jams If you want all the 3/4 frame pics drop me an email and I'll give you what I have, or if you want certain ones, let me know. LILREDGMC |
Active Member
![]() Join Date: Oct 2002
Man I hate to see good stuff go to the scrap yard, I hope all the parts can find a good home.
If no one takes the frame will you sell and ship to me the overload springs and the stabilizer bar? If so please give me a price? Last edited by burb71; 02-04-2008 at 12:36 PM. |
BURB 71
If you're not in a rush, I will keep you posted. I hate to scrap it, but you get tired of looking at it and moving it. Obviously I'd rather let it go as a unit, if someone had a 3/4 that they wanted to restore, do the frame then transfer and do the sheetmetal, but no takers yet. You want the overloads and related brackets, and the front crossmember and brackets, correct. Drop me a note and we'll work it out. My short term problem is that I'm about at the start of the spring outage season, so I will be traveling with work, so some of this may have to sit until later in the spring. LILREDGMC |
#13 |
Active Member
Yes, those are the parts that I want.
All of the Helper Leaf Spring parts and the front Stabilizer Bar, not the crossmember. Time is not a problem for me, just please dont forget about me. Last edited by burb71; 02-06-2008 at 03:41 AM. |
#14 |
Confirmed Truckaholic
![]() Join Date: Oct 2000
Pm'd you, Thanks
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b Daily Driver, 1970 Cst short fleet, all black, 350/350, 1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road 1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72 "My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin" |
#15 |
LILRED-
I need center e-brake cables and attaching hardware:. Any available? (I'm told 66-70 will work, not sure - what I need is in red) |
