01-28-2008, 05:02 AM | #1 |
Parking brake - what are my options?
Truck originally came with a granny 4 speed and had the brake on the tail end of the transmission. I've got the pedal and cables/brackets are no problem but I haven't a clue what I need to do on the drums to hook it up. Can I drill through the backing plate and make these work or do I need new parts?
edit.. this is the passenger side so right = rear of truck Last edited by TravisH; 01-28-2008 at 05:04 AM. |
01-28-2008, 06:22 AM | #2 |
Old Skool Club
Re: Parking brake - what are my options?
I'd be finding a pair of backing plates that already have the parking brake mechanism. That way you'd know what went where and that it was all set.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
01-28-2008, 04:53 PM | #3 |
so are the plates pretty much interchangeable for the next 15 years or do I need 67-72 specific?
01-29-2008, 02:38 AM | #4 |
They all look similar, but I'd do some junkyard searching to verify before you jump in and buy anything.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
01-29-2008, 02:50 AM | #5 |
I have a set of backing platesI took off my truck that has the ebrake hook up of you want them. Pay for shipping and they are yours.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
01-29-2008, 11:05 AM | #6 |
I might take you up on that whatnow
Looking at the plates I can't imagine theres any difference other than the hole but I'm probably short the pivot arm. I'm going to pull off the drum after my paint dries a little |
