Old 01-28-2008, 09:38 AM   #1
68jimmy
68jimmy's Avatar
Pitman arm leak...
Have a leak from the pitman shaft on my gearbox. I've seen a seal kit available from checkauto and was wondering how difficult it would be to r&r the seal??
Thanks in advance,
donovan
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 01-28-2008, 10:41 AM   #2
68jimmy
68jimmy's Avatar
Re: Pitman arm leak...
Ttt
Old 01-28-2008, 01:39 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
I thought about doing it myself and when I asked my dad how hard it would be he told me I'd be better of buying one. The seal kits aren't terribly expensive but I think the rebuild is tricky. Maybe someone else can chime in that has done one and tell you for sure. Sorry I couldn't be of more help.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-28-2008, 02:12 PM   #4
CMars45000
CMars45000's Avatar
They are not too bad... Just keep track of where the preload adjusting nut is on the top of the sector gear cap. It needs to be set back EXACTLY where it is...
Chris
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 01-28-2008, 09:14 PM   #5
68C15
blood type; Retumbo
68C15's Avatar
pull the box and place it on the bench. remove pitman arm with puller tool. pry out old seal being carefull not to damage the shaft or housing. drive in new seal. re-install box.
there is no reason to disassemble the unit for this seal. unless of course you are curious what's inside and plan to buy a new one.
68C15 is offline   Reply With Quote
Old 01-28-2008, 11:18 PM   #6
68jimmy
68jimmy's Avatar
I'll let you know how it goes...
tx
Old 01-29-2008, 04:35 AM   #7
Wrenchbender Ret
I,ve always pulled the sector shaft out. It is easier that way. If you have the steering on center remove the bolts on the cover & tap the shaft out. There is a snap ring, 2 seals, & a spacer between them. Then slide the shaft back in & bolt it down. The adjustment stays the same.
Wrenchbender Ret is offline   Reply With Quote
