PROJECT 7DEUCE
![]() Join Date: Dec 2002
Need some help here........ on 1 1/2 crossmember chop..
Anybody here that has done one what kind of headders are you running...... on a big block.... anyone anyone????
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: Need some help here........ on 1 1/2 crossmember chop..
Mine was sbc w/the c.member sectioned to keep the engine 'towers' the stock length. I used Dynomax 3/4 length for a f-body & they cleared fine.
For comparison, my 67 in the garage has a stock c.member w/stock GM BB towers & has Sanderson 3/4 length headers that clear the same as the sbc Dynomax units.
PROJECT 7DEUCE
Looks like I need to get a set of shortie type headers.. Thanks scoti
