PROJECT 7DEUCE
![]() Join Date: Dec 2002
Vin numbers on frame where they at..
Can anyone show or tell me where the vin #'s are on the frame the frame has had a camaro clip installed on it and the frame #'s are gone. Is there anywhere else on the frame the the numbers would be stamped? The door vin sticker deal has been lost and id really like to get this thing registered monday..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: Vin numbers on frame where they at..
On the '59 it is located in two different spots on the frame. Drivers side just in front of the original location that the gear box mounted, and further back on the same side under the cab..........don't know how they are going to verify it if the front one has been covered or removed. That is one advantage of living in Florida, you can drive anything that you can make roll.........however, that is a down side too.........to many unsafe vehicles on the road....
