01-29-2008, 12:36 AM | #1 |
Nothing to see here.....
Rear U-Bolt Question - Coil Suspension 1/2 Ton
backstory. I am having some 2" drop blocks flamecut for my rear suspension. of course, I will need to get some longer u-bolts. So......
I measured the axle u-bolt on the truck, so could someone verify my numbers? these are my measurements. - from the inside of the arc to the bottom of the threads is 8" - from center of rod to center of rod is 4.25" - the rod itself is 11/16" round - the two nuts are 1" fine thread thanks all......
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
01-29-2008, 10:14 AM | #2 |
Re: Rear U-Bolt Question - Coil Suspension 1/2 Ton
anyone have a u-bolt they can measure?? don't want to order something screwy.....
01-29-2008, 10:35 AM | #3 |
Funny, I was just thinking of doing the same thing.
I have lowered springs but want another half inch or so more (and it's not quite level). Went out this morning and looked at the U bolts to see if I had enough thread to put a spacer in there. I think I can. If you find some longer bolts let us know. |
01-29-2008, 10:45 AM | #4 | |
Looks like on mine that you could go 1/2" to 3/4" with a longer u-bolt, but aftet that you will need one that's longer. I'm just wanting to verify my measurements because I would hate to order 2 incorrect u-bolts. Guess I could always take up horseshoes???!!!
01-29-2008, 11:01 AM | #5 | |
http://www.classicperform.com/
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 01-29-2008 at 11:03 AM. |
01-29-2008, 11:55 AM | #6 | |
Tri, Yep, I meant the wrench size is 1". The round stock is 11/16", so your right, it would be a 3/4" UNF. have to wait 'til I get to work tomorrow and verify in my Bible, the Engineer's Handbook. I'd go with CPP if I didn't have a spring place here locally that can make a pair fairly cheap.
01-29-2008, 01:54 PM | #7 |
There is a shop In Santa Maria Ca. Central Coast Spring, there number is 805 347- 7335, they will make any length u-bolt you need, I dont know if they ship but if not I can pick up and ship, I have used them a few times to do different trucks I have worked on.
01-30-2008, 12:01 AM | #8 |
It's a catastrophic success.
