Old 01-29-2008, 03:13 AM   #1
jcfoote60
Active Member
jcfoote60's Avatar
mounting newer silverado seats
I am going to use 2005 Silverado buckets in my Jimmy, in the past I have used 9 inch grade 8 bolts and just punched through the rocker boxes to mount these type of seats on the outside and using 1/4 inch plates, what have you guys done to try and make these seats mountable and safe? The rocker boxes are pretty tough so my thought was that they are much better to use as a mount point than just the floor pan...any ideas?
jcfoote60 is offline   Reply With Quote
Old 01-29-2008, 06:50 AM   #2
hotrodhomi
hotrodhomi's Avatar
Re: mounting newer silverado seats
A bolt that long creates a ton of leverage. I would not recommend that method. Why not build a bracket and weld it to the floor?
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 01-29-2008, 10:25 AM   #3
BLUE THUNDER
BLUE THUNDER's Avatar
I'm doing the same thing and my idea consists of welding a box frame out of 1"x2" box tubing and utilizing the factory bolt holes to mount the frame to the floor. Then you can weld or bolt the newer seats to that. I'll post some pics of mine when I finish. Later, Mario.
BLUE THUNDER is offline   Reply With Quote
Old 01-29-2008, 01:49 PM   #4
truckster
truckster's Avatar
I used a piece of plate steel and made an adapter plate for mine so I could use the factory bolt holes. I can take a pic tomorrow if you'd like.
truckster is offline   Reply With Quote
Old 01-29-2008, 09:41 PM   #5
vtblazer
vtblazer's Avatar
I have some 2004 Tahoe seats going in mine to, using the method pictured below.
vtblazer is offline   Reply With Quote
Old 02-27-2008, 05:44 AM   #6
darrenr
darrenr's Avatar
I am mounting some different seats too and would like to see those pictures. I have managed to line up the front outside bolts and I'll have to drill new holes for the inner bolts. The problem I'm having is how to bolt, weld or create a bracket for the rear outside bolts for each seat. I was going to use a nickle furtaute bolt anchor unless we come up with something better...
Any and all advice and pics will be appreciated! Thanks.
darrenr is offline   Reply With Quote
Old 02-27-2008, 08:14 AM   #7
truckster
truckster's Avatar
Keep in mind that these came from a 98 extended cab, so they may be a little different. First I test-fitted the seats in the Blazer. I wanted the most forward travel I could get without going forward of the raised area on the floor where the originals mounted. The tab on the 98 seat went forward, so I used a 3lb hammer to bend it backwards. Then I put took measurements and determined the size of the plate. I measured the original locations and drew out a plan on the steel. I drilled 1/2 inch holes so there would be a little bit of wiggle room. I bolted the plate to the floor, and then set in the seat and marked the location for the mounting holes. I made them 1/2 inch also. I pulled the plate out and used 7/16 grade 8 bolts to mount the seat to the plate, then mounted the plate to the floor.
The yellow circles show where the bolts go into the original locations in the floor.
Old 02-27-2008, 04:00 PM   #8
vtblazer
vtblazer's Avatar
Comfy...
Any pics showing how they look inside?
Old 02-27-2008, 07:40 PM   #9
fun in dirt
fun in dirt's Avatar
That looks too simple & effective...I like it!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 02-27-2008, 08:50 PM   #10
r1lorenzini
wow great idea I also like it. i can do it in a truck the same way right?
r1lorenzini is offline   Reply With Quote
Old 02-28-2008, 01:13 AM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Yes, the floors are basically the same, however the inside holes (Tranny tunnel area)
might not be there. There may be dempels there from the factory cause some trucks
were available with buckets. No biggie though just drill some new ones and put plate
underneath the floor also so that it creates a sandwich of the floor sheetmetal. This
should be sufficient enough with the outer holes in the factory spots for the bench.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-28-2008, 03:06 AM   #12
Big J
Its lookin' like a Blazer!
Big J's Avatar
I think mine are 05 Silverado seats. I just centered them up, marked and drilled some holes to start. You have to remove the rear panel of the rocker box to access the under side of the floor for your outer mounting locations. After I had the holes drilled I took some large fender washers and welded some nuts to one side then bolted them up to the floor. I drilled holes down through the floor into the washers and welded them up securing them to the underside of the floor. I did the roll bar mount the same way, just using 1/4" plate instead of individual washers for each hole. I think I used 2 1/2" washers. If you'd have a hard time getting inside the boxes then I really like the plate mount, looks like a slick way to do it. My floors were mostly gone so it wasn't to bad to do.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 02-28-2008, 03:08 AM   #13
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
I went with the plate route. I fabed bolted down some 5/16"X4" bar stock to the orginal holes and then had stubs welded on to fit the placement of the seat. Once you cover it with carpet you can't even tell that there is bar stock there.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 02-28-2008, 05:53 AM   #14
truckster
truckster's Avatar
Here are a couple of pics from last summer...
Old 02-28-2008, 06:28 AM   #15
vtblazer
vtblazer's Avatar
Those are a nice fit IMO.
Look great and have the correct shoulder harness mounting.
Old 02-29-2008, 09:21 PM   #16
tdkosta
tdkosta's Avatar
How is access to the back seats with the newer style seats?
tdkosta is offline   Reply With Quote
Old 03-01-2008, 05:37 AM   #17
truckster
truckster's Avatar
The seats in mine are 60/40 split bench from a 98 extended cab. I think that was the last year before they started building the 3rd door. Both seats tilt and slide forward with a lever on the side of the seat back. At the base of the seat, it slides forward about 6 inches. I think the access is at least as good as with the original seat. And the seat back doesn't hit the windshield when it's forward.
