Old 01-29-2008, 04:39 AM   #1
57larry
rear end swap question
yea, I'm a newby, is there a search mode? anyway, I want to swap out the 6 lug rear from a 69 C-10 1/2 ton to a newer 5 lug rear. I have a 73 C-10 5 lug rear with leaf springs. your help please
57larry is offline   Reply With Quote
Old 01-29-2008, 04:50 AM   #2
BarryB
BarryB's Avatar
Re: rear end swap question
Is your 69 leaf or coils springs on back??
I have seen the newer diffs bolted up to the older coil spring set up. They had to fabricate a panhard bar brace because the 73 up didn't have the panhard bars. And the spring perches are welded on straight whereas the coilspring set up diffs. have the spring perches are on an angle.
Just seems to me it would be easier, to find a 71 rearend already 5 lug and made for the coilsprings
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 01-29-2008, 04:52 AM   #3
joe b
Red face Re: rear end swap question
You can take the brackets off the one and put on the other rear
joe b is offline   Reply With Quote
Old 01-29-2008, 06:04 AM   #4
57larry
yes, that's my question, the 69 has coils and the 73 has leaf springs, can I mate the 2?
Old 01-29-2008, 06:15 AM   #5
502tripower
502tripower's Avatar
You can either remove the old pads from your original rearend housing and reinstall them on the 73' haousing or buy new pads. Here is a pic of my 9" that I did.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 01-29-2008, 02:27 PM   #6
dingo_dan_22
dingo_dan_22's Avatar
You can also take your axles and a 5 lug drum to a machine shop and have them machine down the hub and redrill the axle. When I called around I was quoted between $80 and $140 dollars.
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop
dingo_dan_22 is offline   Reply With Quote
Old 01-29-2008, 02:54 PM   #7
tll74
"Junkyard Dog"
tll74's Avatar
I'm a new to this forum as well. In fact my first reply.The other suggestions are do able but your best bet due to the track bar is to get a 71-72 coil spring rearend out of a C-10. It will be a direct fit with absolutly no modifications. Although it is a couple inches wider. All 71-up 2 or 4wd are wider. The same as the 73 rearend you have. These 71-72 rearends are generally found for 150-200 bucks at a salvage yard. good luck
tll74 is offline   Reply With Quote
