dropping my 65 gmc
Why does it taste purple?
Re: dropping my 65 gmc
Cheap and safe usually don't go together.Front coils and drop spindles and rear drop leafs are the way to go and the way I will be goin when I do it.
You could cut the front springs and take a few leafs out if you wanted to though |
I Thought The Old 65's Had Coil Spring Rears In Them
Depends on how it was optioned. IIRC, GMC were leaf w/coils optional & Chevys were coil w/leafs (leaves?) optional.
chevy only
![]() Join Date: Sep 2006
How low are you thinking? and tire combo
CHEVY ONLY... Nothin Else ! |
probably a 2/4 if that sounds right. still green behind ears. not sure about tire combo. I like nice thick tires instead of low profiles.
Leaf or coil spring rear suspension?
leaf springs in the rear
Flip kit nets more 'useful' drop per dollar. Dropped leafs tend to lose cargo capacity while a flip kit maintains the same capacity as long as adequate clearance is there for axle travel.
Dropped springs up front is the simplest route until you want disc brakes, then go drop spindles.
Tot Roddin'
Contact ECE (Early Classic Enterprises), they will hook you up!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
