Old 01-29-2008, 04:46 AM   #1
68350
68350's Avatar
engine question
I have a 72 chevy shortbox with a 402 out of a 70 gmc. It has an HEI setup in it. It will idle fine, but when you rev it up it will backfire. It has a new fuel pump. Is there anything I can check. Thanks
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 01-29-2008, 05:34 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: engine question
is the timing set properly?
Old 01-29-2008, 08:18 AM   #3
drbyrdman
drbyrdman's Avatar
Re: engine question
Check spark plugs wires are on the right plugs and carb for missing caps on vacuum ports.
drbyrdman is offline   Reply With Quote
Old 01-29-2008, 09:11 AM   #4
Eichorst69
Re: engine question
Timing ???
Rob
Eichorst69 is offline   Reply With Quote
Old 01-29-2008, 09:23 AM   #5
hvychve
To The Levy
hvychve's Avatar
Re: engine question
Dont forget to look for a flat cam, I would deffinately look at the firing order like listed above, not too retarded on timing and cap isnt crossfiring, (water in cap) if all the basics are fine, put you a vacuum gauge on a manifold source and verify steady vacuum readings at idle and cruise, if you having a bouncy needle, you may be lookin at either a broken valve spring, rocker prob. or flat cam. good luck
hvychve is offline   Reply With Quote
Old 01-29-2008, 09:51 AM   #6
truckdude239
truckdude239's Avatar
Re: engine question
timing?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-29-2008, 10:51 AM   #7
tim21391
tim21391's Avatar
Re: engine question
i had a backfiring problem on my 72 402 big block....autozone told me to set my new spark plugs to .035 gap...so i did and it back fired like a son of a gun...so i checked my old plug and it was at .040.......so id check your spark plug gap...if that aint it like the guys said its prolly your timing.....i had it back firing again only when it was cold and my choke was bad so it could be your choke possibly
tim21391 is offline   Reply With Quote
