Old 01-29-2008, 05:31 AM   #1
clemson71guy
clemson71guy's Avatar
places to mount tweeters
i am looking for places to mount tweeters. i am cutting holes in the door for speakers but i dont really want to put my tweeters there because the seat will block some of the sound
so where have some of yall put tweeters?
clemson71guy is offline   Reply With Quote
Old 01-29-2008, 06:53 AM   #2
1972Ryan
Re: places to mount tweeters
mine are in the corners below the hole that is for shoulder belts about 8 inches below that. They look good there. Will try and post pics if I can get over there and take some.
1972Ryan is offline   Reply With Quote
Old 01-29-2008, 06:59 AM   #3
young grasshoppa
young grasshoppa's Avatar
I am probably of no help, but this is how I did mine.
young grasshoppa is offline   Reply With Quote
Old 01-29-2008, 07:57 AM   #4
72 cheyenne pdx
72 cheyenne pdx's Avatar
For optimal sound, you don't want to put your tweeters no further that 6" from the woofer they came with. You could theorically put the tweet on the kick panel and call it good.
Good Luck
SEA
72 cheyenne pdx is offline   Reply With Quote
Old 01-29-2008, 08:04 AM   #5
Andy4639
Old member
Andy4639's Avatar
I took the clothes hanger off the passenger side and mounted the tweeter.
I measured the driver's side and mounted it at about the same spot. They sound good and you don't have to crank it up so loud to hear them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-29-2008, 10:09 AM   #6
clemson71guy
cool, i mite just do that.
Old 01-29-2008, 11:57 AM   #7
kenm78
Broken Down
kenm78's Avatar
Andy4639,
How did you run your wiring???
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 01-29-2008, 12:38 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
wiring would be easy, stuff the wire into the hole, and when it drops out down by the cab corner, run it under the carpet or the chrome thresh plates and up to the radio.
Old 01-29-2008, 04:26 PM   #9
heavy70
heavy70's Avatar
If your truck is equiped with the round a/c vents obove the kick panels i put mine in there.
heavy70 is offline   Reply With Quote
Old 01-29-2008, 07:43 PM   #10
Andy4639
Old member
Andy4639's Avatar
I drilled a seperate hole for the wires and did as Longhorn Man suggested. Wasn't nothing to it.
Heavy70, where does the air come out at for the A/C?
Old 01-29-2008, 11:17 PM   #11
KFreddy
Active Member
KFreddy's Avatar
Mounted mine real nice above the AC vents, used a heavy piece of bailing wire mounted to the vent screw and the speaker screw. Works like a charm and the placement of a tweeter is near perfect.
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 01-30-2008, 12:38 AM   #12
John Fabris
TOTY 2006
John Fabris's Avatar
Put mine into the frame of the stock dash speaker. Recovered the top with black cloth.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 01-30-2008, 01:03 AM   #13
70short
I put mine in the pod's on top of the dash out by the doors. There small enough and with the dash pad being black there are not really noticeable.
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
