Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 01-29-2008, 10:04 AM   #1
ksjh1316
ksjh1316's Avatar
Air Compressor help
Ok Ive decided I need an air compressor and some air tools my arms are getting sore. I have a few questions. What is the min CFM at 90 RPM that will let me be able to use most of the tools I will need and what is the min tank size to get. I don't want to spend a fortune but I want this to work well and it is only for monkeying around on my truck. Thanks for the help
ksjh1316 is offline   Reply With Quote
Old 01-29-2008, 10:08 AM   #2
truckdude239
truckdude239's Avatar
Re: Air Compressor help
go with something like this this should do about everything u need
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-29-2008, 10:17 AM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Get as much CFM as you can afford. You can have the biggest tank money can buy, but if you don't have enough CFM, you will still have to wait for the compressor to catch up. In the average hobby type garage, you would probably be real happy with a 15 CFM compressor on an 80 or 100 gallon tank.
The compressors that are truely suitable for demanding work are going to be expensive though! I have never been able to afford enough air compressor, maybe someday I will
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 01-29-2008, 10:22 AM   #4
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
Did you read the reviews on that compressor? Not good!
TennesseeZ is offline   Reply With Quote
Old 01-29-2008, 10:38 AM   #5
502tripower
502tripower's Avatar
Like anything else if you try and get by with a cheap product you will end up spending more in the long run.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 01-30-2008, 02:06 AM   #6
Blue82Chev
Murph
I have this one for two years now and love it...
http://www2.northerntool.com/product/158284.htm
Mike
Vehicles:
1982 C20
2003 GMC Sierra
Blue82Chev is offline   Reply With Quote
Old 01-30-2008, 03:13 AM   #7
streetstar
streetstar's Avatar
Get the biggest, most capable compressor you can afford if you want to run a sander or paint sprayer someday ---- i bought one 5 years ago (a 6hp Porter Cable for $350), I burned it up in 3 weeks running a DA sander.
It sat for a while before i got around to using it, so by the time i burned it up it was out of warranty and i was told a replacement GE motor was $300.
I currently have a DeWalt compact air compressor (like roofers and carpenters use) -- it works great for everything else (impact wrenches, air hammers, and other things that dont require a big continuous load) ---
The next compressor i get is going to be as big as a water heater and run on 220v --- the small stuff is just too limiting
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 01-30-2008, 03:20 AM   #8
bobthecop
bobthecop's Avatar
I bought an IR 5hp 80 gal tank 18.5 cfm at 90 psi fron Tractor Supply and I love it. Runs a cut-off wheel and air sander great, the tank pumps up while using the air tool, my old 25 gal craftsman caused me to take a lot of breaks. Like has been previously posted, get the biggest hp you can afford, then you will not have to worry about what you need to do with it. I had to wire 220 to the garage and anchor it, and put a longer drain tube in, but it was well worth it.
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 01-30-2008, 04:23 AM   #9
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i agree cheap is expensive
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 01-30-2008, 08:39 AM   #10
Dads 68 GMC
Dads 68 GMC's Avatar
2 stage, 5 horse 80 gallon tank will do you just fine. IR from tractor supply or similar should be adequate for a hobby user. If you think you might use it alot later, you might want to check out Curtis or Kellog or something hope this helps you
Dads 68 GMC is offline   Reply With Quote
Old 01-30-2008, 08:53 AM   #11
ksjh1316
ksjh1316's Avatar
Thanks for the help I just wanted to make sure I didn't screw this up as it is something I don't want to have to repurchase later. Just to make sure I got it right CFM>HP>Tank size
Old 01-30-2008, 08:56 AM   #12
502tripower
I have a Kellog cast iron 2-stage pump 5-HP 80-gallon tank. I have had it for about 25 years now. I replaced the valves in 2005 for about 150.00 and it will go for the rest of my life. I use it in a small cabinet shop but have it plumbed into my shop for building Cars, Trucks, Boats and, Bikes. If you are planning a lot of use spend the extra. I have seen lots of guys buy the Home Depot or other general public type brands with the aluminum single stage pumps and then try and run a shop, DA, glass bead cabinet. Not a good idea. After about 3-years their looking to replace it. Good Luck Dan
98' FXD
2002 2500HD
