01-29-2008, 11:00 AM | #1 |
WIW?? 1969 1/2 ton rear diff 4.10 posi.
I am looking at a posi rearend . It's a 69 model so it is a coil sprung 6 lug set up. So i really would like to know what is a good price to pay for it.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
01-29-2008, 11:25 AM | #2 |
Re: WIW?? 1969 1/2 ton rear diff 4.10 posi.
For buying, I would say anything less than $150 is decent. I'm assuming the gears and carrier are useable. The 4:10 gear might hurt it some.
01-29-2008, 11:54 AM | #3 |
Still Just Havin Some Fun!
around here they are $4-500 for the ones I have found.
a green one with some stuff done to it.... |
01-29-2008, 11:58 AM | #4 |
i sold my last one for $200.00.
did you get your center caps at tims?
i have 67/72 chevy truck parts f/s. |
01-29-2008, 01:05 PM | #5 |
wow, those are bargins. I would say between 400 and 500 since a posi unit alone is 400 and another 100 for the install kit.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
01-29-2008, 09:41 PM | #6 |
computer illiterate
ive been getting 250 for used ones
72 2wd blazer 72 swb 4x4 |
01-30-2008, 12:56 AM | #7 |
I sold one for $500, so if you can get it for $100-300 its a deal. 4:11's are desirable for an OD trans or a race type application, also helps if you are running some rubber.
01-30-2008, 01:48 AM | #8 |
Having issues
In areas where self service junkyards are common, I have a hard time getting anything more than $200 for most rear ends, unless there is something special in them. If I ask too much money, they know they can go to the same place I went to and buy the same axle for less.
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
01-30-2008, 01:58 AM | #9 |
I paid $35 for mine at a u-pull-it but that was a junkyard score...
$250 and up would be a good price for a guy wanting one.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-30-2008, 01:48 PM | #10 |
Yes Bill I got the caps from Tim.
Thanks for dropping them off.
01-30-2008, 02:29 PM | #11 |
01-30-2008, 02:44 PM | #12 |
User #12137
01-31-2008, 02:11 AM | #13 |
Ok but I am pretty sure it is coil springs if not I might let it set.
