Old 01-29-2008, 11:07 AM   #1
westcoastflatbedder
westcoastflatbedder's Avatar
WTB extended front brake lines
Does anyone have ant extended length brake lines for the front of a 72 K10 with disc. brake front end.Just put a 6 inch lift in and was wondering if anyone had any laying around.Please let me know,thanks
westcoastflatbedder is offline   Reply With Quote
Old 01-30-2008, 09:51 AM   #2
shelby987
shelby987's Avatar
Re: WTB extended front brake lines
I used 2wd brake hoses for my truck. I have to take a grinder to the caliper to get the line to sit flush to the rear of the caliper (there was a raised portion for a round banjo fitting, and 2wd have a square flange). I ground the rear of the caliper flat (30 secs. at most, could be done with a dremel if you don't have a grinder). I have not had any problems, or leaks, and I would say I MIGHT be able to handle a 6" lift without issue......I know 4" isn't a problem.
I had to go to NAPA to get the lines.....I think I bought lines for an 82 C10.
good luck!
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 01-30-2008, 11:29 AM   #3
Twistedsteel
Twistedsteel's Avatar
X2
Twistedsteel is offline   Reply With Quote
Old 01-30-2008, 11:37 AM   #4
1969k10stepside
I went to the parts store and got stock hoses for a late 70s Chevy K10 since there were none for a 67-72 in stock.They are long enough with about a 6" lift.I've got 5" lift springs up front on mine and had no issues using those lines.The hoses were for metric banjo bolts though and mine has the standard banjo bolt being a Dana 44...
1969k10stepside is offline   Reply With Quote
Old 01-31-2008, 10:28 AM   #5
69GMC4x4sdca
Check out www.inlinetube.com they can hook you up
69GMC4x4sdca is offline   Reply With Quote
Old 01-31-2008, 11:54 AM   #6
JayG
Formerly ADHDCARGUY
JayG's Avatar
Check out your local stock car racing parts store. Locally, I use Smileys. Good prices. Big selection.
Jay
67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C.
54CHEVY - BURB, beginning construction(well, i gotta take it apart first!)
36FORD PU - WAITING
38CHEVY - 2DR SD,CHASSIS FINISHED
46CHEVY - BURB - waiting
JayG is offline   Reply With Quote
Old 02-03-2008, 05:41 AM   #7
boostat4500
I have a pair sitting on my work bench. PM me with an offer if your still looking for some.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
