Need help with tilt column
Today I was out working on installing my tilt column I had a issue with the column to firewall seal. It was installed backyards. Without taking the column apart from the bottom end I could not find a way to fix it. I tried reversing it but it kept flipping back over. Stubborn piece of rubber
![]() After I cut it the rubber was kinda shredded. In short I need a new one and have one on order but here is the $64000 question. How do I install it? Do I need to remove the bottom end of the column to install? Area circled in red in pic.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
TILT COLUMN GURU
![]() Join Date: Dec 2006
Re: Need help with tilt column
If I were you I would take it back to where you got it. You are going to have to completely disassemble the column to remove the shift tube this should be done by an experienced tech.
The only thing in my way is the linkage connector on the column. Could you stop at that point? Or by taking that clip off mean that everything is coming out?
![]() Join Date: Aug 2003
I think it's about impossible to do without cutting the rubber or taking the column apart.
Anyone have the tilt column breakdown diagram? Did a search but came up empty.
#6 | |
![]() Join Date: Apr 2005
http://67-72chevytrucks.com/vboard/s...d.php?t=157328
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Thanks Rob.
This is what I did and didn't have to take the column apart. Some may not agree with this, but tough, it worked for me. I removed the lower clip that holds the bearing in place. I then "Bent" the shifter arm to a point where the rubber seal fits over it. I then straightened the shifter arm back out and re-installed the bearing clip. I didn't have to cut the seal. I've did a few columns like this and have never had an issue with the shifter arm breaking. That arm is thick steel, and would have to take a lot of bending back and forth to break. If you don't want to do this, then take the column apart.
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 01-29-2008 at 09:12 PM. |
Firefighter
You can do it without disassembly, I have done it several times it will stretch over the arm!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Bending the shift arm is the way I have always gotten them on or off.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
I bent the arm thing when I did mine. Didn't break so I guess it was o.k. to do it that way.
Yes, this can be done. I JUST HAD A MAJOR BRAINFART when you asked. That's why this board is so helpful.
