Old 01-29-2008, 03:15 PM   #1
tll74
"Junkyard Dog"
tll74's Avatar
restoration tips
I'm doing a frame of restoration on a 72 C-10. Does anybody have info or direction as to where I can find out the original finish on the nuts, bolts, clips, and etc. For example the fender bolts, cage clips, brake-fuel line bolts, spring bolts, u-bolts for lower a-frames, hood hinges, shift linkage, to much to list. thanks
tll74 is offline   Reply With Quote
Old 01-29-2008, 07:38 PM   #2
JimKshortstep4x4
Re: restoration tips
The only written finish recommendations that I have seen were by Eastwood and Year One. I have always tried to duplicate existing colors to a point as the auto companies used a variety of finishes and shades.
Some of the board members have done a lot of research on finishes and where they apply and they may have a list. Someone like board member 71 Super knows the finishes off the top of his head and there are probably others.
I would suggest making up your own list so that specific answers can be given.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-30-2008, 02:22 AM   #3
71 super
71 super's Avatar
the bolts are going to be black oxide- going to look flat against gloss. If you have specifics in mind pm with your list and I will try to help out.
71 super is offline   Reply With Quote
