Old 01-30-2008, 12:01 AM   #1
kqql
Power Steering
Hello, I'm new to this site but have been building since the late 60's. I'm stuck on power steering mounting for my 71 shortbed. I used the engine out of a 1972 suburban (350) took the pump off while redoing the engine and cannot figure out how to mount it. It's the late model pump,I think there was a change mid year and cannot find any info or pictures. I might be missing a bracket. Is ther anyone that can help with some info,hopefully pictures. The pump is used from 73 on up. Thanks
kqql is offline   Reply With Quote
Old 01-30-2008, 12:06 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Power Steering
Here is a stock mount
sneakysnake is offline   Reply With Quote
Old 01-30-2008, 12:09 AM   #3
kqql
Re: Power Steering
Thanks,I have the later pump.
Old 01-30-2008, 12:13 AM   #4
sneakysnake
Re: Power Steering
73+
Old 01-30-2008, 12:15 AM   #5
kqql
Re: Power Steering
Thank You
Old 01-30-2008, 12:23 AM   #6
Jim_PA
Re: Power Steering
here's a real-world pic. I was told mine came from somewhere in the 70's, and I'm not sure it's 100% correct, but anyway...
Jim_PA is offline   Reply With Quote
Old 01-30-2008, 12:24 AM   #7
kqql
Re: Power Steering
Now where does the alt. Mount? I have way to many brackets lying around
Old 01-30-2008, 07:14 AM   #8
65 on 24's
65 on 24's's Avatar
Re: Power Steering
ok i got a Q then. my 65 has been swap over to power steerin but my bracket dont look anything like them mine bolts to the block and then you unbolt the pump to tightin the belt. what year is it off of
ridin big yo
5in cpp lowerin springs in back
lowered 3in in front with cut springs for now
5 lug swap and disk in front
5 lug and disk in the rear with 3.23 gears
mild 350/400heads
7547weiand intake
600 Edelbrock
chrome block hugger headers
2 1/2 pipes in to a x pipes
super 40 flows and turn downs
turbo 350 with shift kit
65 on 24's is offline   Reply With Quote
Old 01-30-2008, 07:15 AM   #9
65 on 24's
65 on 24's's Avatar
Re: Power Steering
Originally Posted by sneakysnake View Post
73+
not like this one
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 01-30-2008, 07:40 AM   #10
jay6891
Car Knocker
jay6891's Avatar
Re: Power Steering
65 on 24's, that would be the top pic that was posted. 72 and older. If you look at the diagram you can "see" where the pump would mount and the adjustment bolts are at the rear of the reservoir top with a slot, bottom as a pivot.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 01-30-2008, 11:47 AM   #11
65 on 24's
65 on 24's's Avatar
Re: Power Steering
mine dont look like them ill put pic up
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 02-01-2008, 01:05 AM   #12
kqql
Re: Power Steering & alt. Mount
I hope someone out there has a 1972 suburban with the later power steering pump and the 350 engine. I took this engine apart about 4 years ago and am just getting back to putting it back in my 71 shortbed. I cannot figure out the left side mounting for the p/s pump and alt. The brackets I have I cannot for the life of me figure out how they go. It's driving me nuts and I've been building since the late 60's. If I mount the power stering the alt won't fit and if I mount the alt the power sreering wont fit. I know all od f the a/c mounts on the r/s of the engone
Old 02-01-2008, 01:07 AM   #13
kqql
I hope someone out there has a 1972 suburban with the later power steering pump and the 350 engine. I took this engine apart about 4 years ago and am just getting back to putting it back in my 71 shortbed. I cannot figure out the left side mounting for the p/s pump and alt. The brackets I have I cannot for the life of me figure out how they go. It's driving me nuts and I've been building since the late 60's. If I mount the power stering the alt won't fit and if I mount the alt the power sreering wont fit. I know all of the a/c mounts on the r/s of the engine
Old 02-01-2008, 01:22 AM   #14
ryan913
Re: Power Steering
Can you post a picture of your brackets? Does it have a short or a long water pump? You said it was a later pump which one would assume it was a long pump. I am also assuming you have drilled heads.
ryan913 is offline   Reply With Quote
Old 02-01-2008, 01:29 AM   #15
kqql
Re: Power Steering
It's the short pump and yes There are 3 holes in the head. I am new to this board and am going to try to post a picture
Old 02-01-2008, 01:31 AM   #16
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Power Steering
The two different diagrams shown in this thread are #1 is for a short water pump. A short water pump was used in all of the Trucks, Suburbans, Blazers, and Panels from 1967 to 1972. If the engine that you took out of your 72 Suburban has the #2 style pump and bracket, it is a transplant from either a Chevy car or 73 and lator Pickup, Suburban, or Blazer. It is a pump and brackets for the long water pump. The alternator sets on the passinger side of the moter with that style power steering pump. I will take a picture in a bit to show you how everything goes. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 02-01-2008, 01:38 AM   #17
ryan913
Re: Power Steering
I think I have the same style you have. Does your pump also use the bracket that bolts to the motor mount? Unlike the the first illustration posted.
Old 02-01-2008, 01:45 AM   #18
kqql
Re: Power Steering
How would I post a picture or where do i go to learn. I have the pictures
Old 02-01-2008, 01:51 AM   #19
ryan913
Re: Power Steering
Can you send them to me at jo386001@ohio.edu? Thanks.
Old 02-01-2008, 01:52 AM   #20
Classic Heartbeat
Re: Power Steering
When you reply to a thread, scroll down to where the additional options box is. There you will find the manage attachments button. Click on it and it will bring up another box that have browse buttons on it. Click the browse buttons, select your picture from your computer and when done click the upload button. If your pictures are small enough, they will upload onto this site and all you will have to do from there is to click the submit reply button. If they are too large you will have to shrink them and try all over again. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 02-01-2008, 01:59 AM   #21
kqql
Re: Power Steering
Here are some pics
Old 02-01-2008, 02:06 AM   #22
Classic Heartbeat
Re: Power Steering
Looks like you have a short water pump and are trying to use the power steering pump and brackets for a long water pump to me. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 02-01-2008, 02:18 AM   #23
kqql
Re: Power Steering
The pump I took off is a short pump I have the old one and all of the pulleys I have line up to the short pump. Does that make sense???
Old 02-01-2008, 02:19 AM   #24
ryan913
Re: Power Steering
Yep! The power steering bracket is for the long water pump.
Old 02-01-2008, 02:29 AM   #25
Classic Heartbeat
Re: Power Steering
You are using the short style water pump alternator brackets, and the long style water pump power steering pump and brackets. They will not work together. The power steering pump gets in the way of the belt for the alternator. You need to find the short style water pump, power steering pump and brackets. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
