Let me see if I've got this straight. If you're going to bolt a Chevy TBI intake manifold to your engine (crate 350) you need "center bolt valve cover" type heads. My valve covers bolt on the side. Therefore I can't just find a stock, small block tbi set up and just bolt the manifold to my engine? If yes, what are the ways around this problem?
Thanks.
Re: Center bolt valve cover heads?
The holes for the intake around the crossover (hole in the center of the intake side of the head) are drilled and tapped at an angel, you could ream out the holes on the intake to take the bolts at an angle rather than straight up. If it is aluminum have it tig'd and redrill the hole.
#3 | |
![]() ![]() Last edited by Zonaman; 01-30-2008 at 02:46 AM. |
i've seen this done by a backyard fool--- the fuel system worked fine, but he had ignition problems, so i never saw the long term outcome of this guy's project.
Have you checked any of the aftermarket manufacturer's to see if you could a nice pretty Edelbrock or Holley intake for it? I don't if i recommend this or not, but i've seen performance manifolds used with TBI by using a 2 to 4 bbl adapter plate as well
Are you retired too? Nonsense! I'm in my prime |
Retired Air Force Veteran
![]() Join Date: Aug 2007
I have center bolt heads and I am running an Edelbrock Performer Manifold, no modifications - they make one for those heads. Originally had fuel injection (ole' Carter AFB) but now I am running a Holley 670 Street Avenger Carb
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
He's going the other way non-tbi heads to a tbi intake. I guess any fool with a drill could try or see if one of the intake manufactures make an intake to fit the early heads for a tbi?
Does anyone make such a manifold?
![]() Join Date: Aug 2005
Didn't 1987-1990 TBI 454's have a Quadrajet intake manifold with an adapter for the TBI unit? I think it was even water heated. Wonder if one of those would work.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
