Old 01-30-2008, 08:35 AM   #1
dan468
dan468's Avatar
steering shaft question
I understand what holds the steering column on the truck, but what holds the inner shaft in the column? what keeps if from sliding up and down?
thanks
dan
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 01-30-2008, 09:45 AM   #2
JimKshortstep4x4
Re: steering shaft question
There is a spring on the bottom which pushes the lower bearing upward, (also, pulling the shaft downward) . The spring is held in place by a large washer which is held in place by the joint on the shaft extension.
On the upper end the steering wheel holds a spring against the turn signal canceler which fits against the upper bearing.
So to answer your question two springs reacting against each other hold the shaft in place with the help of the steering wheel and extension shaft.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-31-2008, 11:17 PM   #3
RustyParts
RustyParts's Avatar
Here's an exploded pic from LMC's catalog. The items in the red box hold the shaft together.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 01-31-2008, 11:50 PM   #4
dan42
dan42's Avatar
Here's a picture of the lower seal - the clip holds the two shafts together. The second picture is the joint underneath the seal.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 02-04-2008, 01:14 PM   #5
dan468
dan468's Avatar
Great thanks guys. I took the spring off without knowing what it does. Everything fits nice and tight now.
thanks again
68 C-10
Build thread
