Old 01-30-2008, 10:12 AM   #1
muddpile
muddpile's Avatar
Hood sits too high at the rear?
I know this is a common problem on these trucks, but with new hood hinges it should suck right down into where it's supposed to be I would think. I have the hinge mounted as low as adjustably possible, but it's still up 1/4 of an inch. Is there any way around this aside from slotting the hinge holes further (which I'm willing to do)? It's on the drivers side. The passenger side is good. The truck is a 72. Thanks!
muddpile is offline   Reply With Quote
Old 01-30-2008, 10:36 AM   #2
Ilike 72"s
Re: Hood sits too high at the rear?
I just saw the same thing on a friends pickup. Hood up high in the back. I noticed that the springs were a smaller spring than mine. He found a set that was like mine, (the correct ones) and that solved the problem. He even had to adjust the bracket back up about midway. Hope it works for you. Dennis..
Ilike 72"s is offline   Reply With Quote
Old 01-30-2008, 10:40 AM   #3
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
Yea, my hood sits too high in the rear. Actually started rubbing on the driver's side fender on the way down to norwood....gotta fix it before sandy beach. Neglect is a bad thing
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 01-30-2008, 11:02 AM   #4
CG
BlahBlahBlah
There is a FAQ on how to fix this. I can never find the darn thing though. Im sure someone will post it up.
Old 01-30-2008, 12:13 PM   #5
396 SS
396 SS's Avatar
to adjust the hood to it's lowest point ,at the rear bolt the hinge goes all the way down , at the front bolt the hinge goes all the way up
396 SS is offline   Reply With Quote
Old 01-30-2008, 01:17 PM   #6
Texasbigblock
Texasbigblock's Avatar
I have seen this problem on a few of these trucks and so far everyone i have messed with had new cowl weatherstripping......the new stuff from LMC isnt made like the original so it doesnt roll back when u close the hood. So if u have new weatherstrip trim about 1/4 inch off of it.....worked for me
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 01-30-2008, 01:19 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
One adjustment that seems to work most of the time.
1.Open hood
2.loosen hood bolts
3.lift front of hood(put some pressure on it)
4.continue to hold pressure.tighten hood bolts.
5.Carefully close hood to make sure it doesn't rub or hit anywhere.
Not a sure fire fix but it does work quite often.Also some of the aftermarket hinges cause this.They tend to be "JUNK" and will not last.I know some board vendors will only sell the GM replacements.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-30-2008, 01:53 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Here's the procedure posted by Huck:
To get the back down with existing hinges---open hood----loosen the three bolts that attach hinge to fender (both sides). Now push the hood up till the hinges stop moving, ---now push it open a bit more to preload the hinges. Tighten hinges. (two people make it a lot easier--hehehe) now carefully lower the hood--this may take a few adjustments to get it to sit just right (height wise). You may need to adjust the hood front to rear to allow for proper clearance with the cowl.
LockDoc
Leon
Old 01-30-2008, 02:16 PM   #9
CG
BlahBlahBlah
LockDoc
I looked everywhere for that to post here...where the heck was it?
Old 01-30-2008, 10:38 PM   #10
LockDoc
LockDoc's Avatar
CG, I just typed "adjust hood" into the "Search This forum" box then ticked the "Show Posts" and it was about a half page down….
LockDoc
Leon
Old 01-30-2008, 10:47 PM   #11
CG
BlahBlahBlah
Sheesh how simple was that? Thanks for the heads up.
Old 01-31-2008, 01:02 AM   #12
gonline71
gonline71's Avatar
My original hinges and springs were shot so I purchase an aftermarket set. Same problem, the hood sat up high in the back. When I sat the new hinges next to the old, I noticed the new ones were not closing completely. They were binding on a piece of the hinge. Had to grind it a bit to get it to close completely.
Worth a look.
gonline71 is offline   Reply With Quote
Old 02-05-2008, 03:53 AM   #13
muddpile
muddpile's Avatar
Thanks guys! These are new ones, and I don't belive they are GM's. I'll check out everything that's been listed.
Old 02-05-2008, 09:36 AM   #14
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Seems like I saw a post on this the other day....
Here's GM parts numbers for hood hinges:
391-1705 LH
391-1706 RH
Member Nr. 2770
Old 02-05-2008, 10:38 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I have the same issue... looks like I can now resolve that problem. 1,532,497 to go...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
