Old 01-30-2008, 11:46 AM   #1
nds1968
nds1968's Avatar
pics of stock wheels
Anyone have pics of stock wheels and hubcaps. Just wanna make sure thats the route I want to go. Even though I not even close to the end of my project.
nds1968 is offline   Reply With Quote
Old 02-02-2008, 09:11 AM   #2
67C10SWB
Re: pics of stock wheels
Nice truck!! Hope the build is going well. Would you be interested in selling your center caps? I have stock 67 long bed that is going to be my sons and it will be some time before anything will get done.. They are shot on this truck.. Thanks, Mike
67C10SWB is offline   Reply With Quote
Old 02-02-2008, 10:27 AM   #3
Sweet72
Sweet72's Avatar
Off topic, but I gotta ask... What did you do to the steel bed floor to make it so slick? Filler?
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 02-02-2008, 11:51 AM   #4
kxnomore
kxnomore's Avatar
Here's a few. The first is a 3/4 ton 4 X 4, the second is the 2 wheel drive 3/4 ton, and the last is a Cheyenne 10 "full wheel cover" option.
kxnomore is offline   Reply With Quote
Old 02-02-2008, 12:23 PM   #5
Yeller68
Active Member
Yeller68's Avatar
Here's what mine look like.
Yeller68 is offline   Reply With Quote
Old 02-02-2008, 12:42 PM   #6
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Here,s the C10 King's farm truck and his black 72.
KevsClassics is offline   Reply With Quote
Old 02-02-2008, 01:11 PM   #7
franky69c10
chevy runs deep
franky69c10's Avatar
more pics PLZ
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 02-03-2008, 07:44 AM   #8
nds1968
nds1968's Avatar
I hammered out the dents. Had it blasted then started blocking it down with filler. I cut blocks out of wood to fit the contour of the ribs. I then sprayed it with filler primer and sanded it several times... The filler isn't as thick as it looks. I got the floor pretty straight with the hammer... A big hammer. I have over a hundred hours on the floor though. But working on the truck keeps me from getting into trouble!
Old 02-03-2008, 09:19 AM   #9
463
463's Avatar
i just love them all.
463 is offline   Reply With Quote
Old 02-03-2008, 10:35 AM   #10
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Here is my 67 GMC & my 67 Chevy (the chevy is 5-lug & has early square body wheels)
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-03-2008, 12:05 PM   #11
67_C-30
I have a radical idea!
67_C-30's Avatar
Here's some I have saved.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
