Old 01-30-2008, 01:17 PM   #1
MisterE72
Keep Your Nose Clean
What gear ratio is best for my truck?
Greetings folks. I'm ready to order some rear end gears for my c10. It has a 12 bolt possi, with 3:08 gears. I'd like to go with something different, that won't wind the engine at highway speeds, but has some launch. Here some numbers to think about: 383 stroker, 350 turbo tranny, and 20's with 275/35/20 tires. Any advice is greatly appreciated.
MisterE72 is offline   Reply With Quote
Old 01-30-2008, 01:26 PM   #2
Madman1
Re: What gear ratio is best for my truck?
I am running a 350 with a Weiand 142 Supercharger, 18" rear wheels, TH350 Trans., and I just installed 3:73 gears with a Detroit Truetrac differential and I couldn't be happier. It gave me the low end that I wanted and doesn't wind up too tight on the top end. Good luck with your search!
Madman1 is offline   Reply With Quote
Old 01-30-2008, 01:34 PM   #3
heavy70
heavy70's Avatar
3:73's would work the best, it would have alot of bottom end especially with the 383 depending on what grind your cam is.
heavy70 is offline   Reply With Quote
Old 01-30-2008, 01:36 PM   #4
WorkinLonghorn
WorkinLonghorn's Avatar
WHat's the diameter of those tires? I don't see why,with 3.07 gears,you'd be reving too high. What TC are you running?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-30-2008, 01:44 PM   #5
Shyguy
Junior Member
Shyguy's Avatar
My son has a 454 in his '70 Chevy and is running 3.42 I think and likes them.
I am running a stock 350 with 3.73s and they give me what I want on the highway. Of course I tend to drive slower than some.
I am turning around 2500 rpms at 60 mph which seems to be ok.
Danny -SEMO
Shyguy is offline   Reply With Quote
Old 01-30-2008, 01:57 PM   #6
MisterE72
I'm guessing the overall diameter is about 25 inches. I haven't bought the converter yet. Ant recomendations on the TC?
Old 01-30-2008, 03:22 PM   #7
tll74
"Junkyard Dog"
tll74's Avatar
I say 3.42 and here's why. First, you have tons of low end unless you over camed it. You don't have a overdrive. And at 25 inches you have a "short tire". With a 3.42 ratio, auto trans w/o lockup convertor, and a 25 inch tire your RPM @ 60 MPH will be 2757. Here's the formula to calculate RPM.
Ratio X MPH X 336 divided by tire diameter. 3.42 X 60 X 336 Divide by 25 =2757 RPM. 3.73 would be 3007 RPM. I don't think the convertor stall will affect total RPM at cruise speeds. For a lock up convertor or manual trans subsitute the 335 for the 336.
Just my thoughts.
Paying closer attension to your question I realize you are looking to lower the RPM. Your gear choice for aftermarket gears may end at 3.08. The factory options were 2.56, 2.76, 3.07, 3.40-3.42, 3.73, 4.10 and 4.56. just due the math.........
tll74 is offline   Reply With Quote
Old 01-30-2008, 03:28 PM   #8
MisterE72
Smile Re: What gear ratio is best for my truck?
Just my thoughts.
I had never seen the formula before today. I'm a peson who works best with real data or formulas. I will definitey write this one down on the garage wall. Thanks. Mr.E
Old 01-30-2008, 03:42 PM   #9
wild one
Registered.........
wild one's Avatar
Here's a few sites for calculating tire size, RPM, one that compares your original size tire to your new tire, and one for tire size and width.
http://www.therangerstation.com/tech...nch_Tires.html
http://www.csgnetwork.com/multirpmcalc.html
http://www.miata.net/garage/tirecalc.html
http://victorylibrary.com/mopar/car-tire.htm
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 01-30-2008, 04:13 PM   #10
KFreddy
Active Member
KFreddy's Avatar
A 275/35/20 tire has a diameter of 27.6 inches.
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 01-31-2008, 02:42 AM   #11
Psycho71
Psycho71's Avatar
As for the TC, you should get what will compliment your cam the best. Whoever ground your cam shuld be able to point you to the correct stall speed for yur application.
As for the gears, throw some 3:73's in there, and call it good. If it twists too many rpm, just put an O/D in it. We're all made of money right? LOL.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 01-31-2008, 04:20 AM   #12
BigSky71
LAIDOUT
BigSky71's Avatar
Jay
Money for nothing and over drive trannys for free! Man I wish, I need one!
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 01-31-2008, 10:07 AM   #13
MisterE72
Jay
I'm on a teachers salary. But I love my job.
Old 01-31-2008, 10:19 AM   #14
tll74
"Junkyard Dog"
tll74's Avatar
Sorry Guys!!!!!!!! I had a couple figures mixed up and wrong. The 336 and 335 are wrong. The 336 figure applies to the manual and lock up auto's.
The other figure for auto's w/o lock up is 355. Did this off memory at home. Sorry for the mistake. good day
Old 01-31-2008, 10:49 AM   #15
jim zag
ENGINE BUILDER
jim zag's Avatar
I have a 383 with a turbo 400 and stock torque converter. My truck has 3.07 gears and 255 70 15 tires. The tires are 29 inches tall. That stroker engine makes so much TORQUE, I can spin the tires any time I want. Here is my suggestion. Try it with the 3.07 gears first. You might like it the way it is.
JIM ZAG
jim zag is offline   Reply With Quote
Old 02-01-2008, 11:21 PM   #16
KFreddy
Active Member
KFreddy's Avatar
Though Jim is new to the game; post wise anyway, welcome Jim... I have to back him up on this one. If your engines worth it's salt in TQ #s a 3 speed tranny with about a 3.08 gear will make you want to propose marriage....
Just Ask the guy in the, temp tag, 2008 Dodge Charger SRT8 that tried me in a little 30 to 90mph romp... My 3.08's and ZZ-BIG staved off the "Hemi" Dodge whilst smoking the 29' inchers all the way 'till the next red light. He couldn't even look at me as we sat side by side at a dead stop at the red light, never mind try me again. I was gonna give him an E for effort and a T for nice try, but he just fiddled about with his radio...
The moral of the story, 8 mpg priceless...
And my A/C works...
Old 02-02-2008, 01:44 AM   #17
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
VERY well said, and I was about to say something about that. The 3.07 gear gets a good cruise RPM, and the 383 should have enough torque to not even be phased by the taller gear.
Old 02-02-2008, 02:39 AM   #18
mrein3
mrein3's Avatar
Why not 3.73s and a well built 700r4? I'm thinking that is the best of all worlds.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-02-2008, 04:52 AM   #19
KFreddy
Active Member
KFreddy's Avatar
I think that 3.73s and a 4 speed is a nice set up, however the original post mentioned a 12 bolt posi, 3:08 gears, 383 stroker, 350 turbo tranny, and 20's with 275/35/20 tires.
