Old 01-30-2008, 01:28 PM   #1
pat123
Pat
pat123's Avatar
stock radio
i was wondering if my radio is stock. its from my 69 chev
sorry the pic isnt the best quality
pat123 is offline   Reply With Quote
Old 01-30-2008, 01:39 PM   #2
whitesswj
Embrace the Redneck
whitesswj's Avatar
Re: stock radio
I'd have to say no. The font, for one, is not from the era but maybe post '75.
I do have to say, It does look nice sitting in there.
If it aint broke don't fix it.
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 01-30-2008, 08:17 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: stock radio
that's aftermarket
Old 01-30-2008, 08:43 PM   #4
70GMCer
70GMCer's Avatar
Re: stock radio
aftermarket also....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-31-2008, 02:20 AM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: stock radio
Lots of aftermarket radios for shaft-style mounting were sold to replace the AM radios that became obselete in the mid-70's in most of the small radio market areas. Bigger cities, like NYC, SF, etc., that had FM broadcasting capabilities in the '60's had a better record of a vehicle having an AM/FM radio from the factory.
But those who told you it is aftermarket are right. Sears may not have sold that particular one, but I know they sold a bunch of 'em.
Member Nr. 2770
Old 01-31-2008, 03:05 AM   #6
pat123
Pat
pat123's Avatar
Re: stock radio
ya i didnt think it was stock
so the dash was probably cut to fit it in?
would it be am fm?
Old 01-31-2008, 03:11 AM   #7
WorkinLonghorn
WorkinLonghorn's Avatar
Re: stock radio
On mine they put an adapter plate on there and the aftermarket stereo fit without cutting.
Yours might have the same plate.
I'd show you a pic but it's embarrassing.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 01-31-2008, 03:29 AM   #8
68gmsee
Active Member
68gmsee's Avatar
Re: stock radio
would it be am fm?
It may have been cut. You can see the indentation where the orginal knobs went.
However, you could delete the opening with either a stock delete or make one yourself. Then you could put a radio/cd player of your choice in the glove compartment like some others have done.
68gmsee is offline   Reply With Quote
Old 01-31-2008, 06:31 AM   #9
Longhorn Man
Re: stock radio
they may have nibbled a little on the shaft holes.
Kinda hard to tell if it is an AM/FM... I only see one scale on the lens.
Old 01-31-2008, 07:08 AM   #10
pat123
Pat
pat123's Avatar
Re: stock radio
they replaced the anntena so that could mean that it could be am/fm
i was going to put a cd player in the glovy
Old 01-31-2008, 07:59 AM   #11
Longhorn Man
Re: stock radio
do you see am and fm on the scale?
is there a way to turn it from am to fm?
They probably added an antenna, since it was probably a truck with no radio from the factory, was there one listed on the SPID? The stock antenna woulda plugged right into the new radio.
