Old 01-30-2008, 02:29 PM   #1
cstm68
cstm68's Avatar
frame notch
i have a frame c notch kit for my 68 sorta like this one
http://www.classicheartbeat.com/cata...otch%20kit.htm
but its a little diferent. it is a different notch and it is a lot thicker steel.
does anyone have any info on installing these or perhaps a (how-to) link ??
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 01-30-2008, 03:01 PM   #2
TravisH
TravisH's Avatar
Re: frame notch
http://67-72chevytrucks.com/vboard/s...d.php?t=195566
TravisH is offline   Reply With Quote
Old 01-30-2008, 03:08 PM   #3
MisterE72
Keep Your Nose Clean
Re: frame notch
Here is how my self and a buddy did it.
1) Cut it using a grinder with metal cutting wheel. Be sure its aligned accordig to instructions. The CPP kit is aligned using holes on the frame.
2) Welded it for extra strength
3) Bolt it up.
The web site is http://www.classicperform.com/tech_a...ch/c-notch.htm
MisterE72 is offline   Reply With Quote
Old 01-31-2008, 02:30 AM   #4
cstm68
cstm68's Avatar
Re: frame notch
is it possibel to do with the truck put together. with all the suspention and the bed on.
Old 01-31-2008, 03:46 AM   #5
shifty
Questionable
shifty's Avatar
Re: frame notch
With how easy it is to remove the bed, you'd be crazy to even attempt such a thing. If you do happen to do this, be sure to support the section of frame in front of and behind the axle BEFORE you cut your notch!!! If you do not, the frame will absolutely risk bending downward, and you're gonna be pissed.
I tore my truck down last night (pic below) for something super special that I'm tossing into my project. With that said ...
Take it from me: Two main bolts hold the front clip to the frame, four bolts holding the cab to the frame, and I think there were 8 small bolts (and two straps that the PO never bothered to re-install) holding the bed to the frame (via the cross rails). There are a few small bolts here and there that you'll find, and a few wires that are easily disconnected...
Bottom line: Three guys were able to remove my bed, rotate it and put it up against my wall as you see pictured below. It took less than 15 minutes from start to finish. If I were notching myself, it would have saved me several hours of tweaking my body out of shape to get under the truck and weld in uncomfortable places/bad positions.
I strongly recommend removing the bed. Just my 2¢
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-31-2008, 05:40 AM   #6
cstm68
cstm68's Avatar
Re: frame notch
ok well i can take the bed off no problem, ive done that about 5 times now. but an it be done with the rest of the frame and rear suspention together.??
Old 01-31-2008, 05:41 AM   #7
shifty
Questionable
shifty's Avatar
Re: frame notch
I've seen it done by other members here before. I would ask in the suspension forum, though, just to get a professional opinion from people who specifically deal with suspension. The specialty sub-forums are superb for that. Don't take my word for it - I can't weld worth a damn, and I have never notched a vehicle, only watched other people do it and gotten pointers from them just in case I do eventually get around to it.
Old 01-31-2008, 10:51 AM   #8
Hart_Rod
Hart_Rod's Avatar
Re: frame notch
It can be done, I did it on my surburban, but it's a pain though. I built 2 frames later and installed them on the bare frame. WWWWAAAAAYYYY easier!!!
Shifty, you've been holding out, what ya got planned, .
Hart_Rod is offline   Reply With Quote
Old 01-31-2008, 02:05 PM   #9
SCOTI
SCOTI's Avatar
Re: frame notch
I installed the same 'bolt-in' c-notch that's posted in the pics. I removed the bed to gain better access & feel it makes the job much easier. But.... it can be done w/the bed still on (most likely w/alot more swearing ).
I also welded mine after bolting it in. I did the initial install @ home w/a cut-off wheel, drill, & hand tools. Then, a few weekends later @ work I got a couple of co-workers to help lift the bed back off & welded it in. I felt it was worth it for the added sense of security when I tow my car trailer.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-31-2008, 02:26 PM   #10
cstm68
cstm68's Avatar
Re: frame notch
ok cool thanks. the kit i have is a little different. it is alot thicker steel and a little different style. i will get some pics of it soon.
Old 01-31-2008, 02:38 PM   #11
cstm68
cstm68's Avatar
Re: frame notch
here is my kit
Old 02-01-2008, 12:29 AM   #12
shifty
Questionable
shifty's Avatar
Re: frame notch
In due time, my friend
Old 02-01-2008, 01:47 AM   #13
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: frame notch
Pages 14, 15, & 16 in my 67 panel project address the instalation of that "C" notch kit with the Panel body still on the chassis. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 02-01-2008, 03:57 AM   #14
SCOTI
SCOTI's Avatar
Re: frame notch
What brand c-notch is that?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-01-2008, 04:16 AM   #15
cstm68
cstm68's Avatar
Re: frame notch
im not shure. it was given to me bacause the guy was not going to use it.
Old 02-01-2008, 04:59 AM   #16
shifty
Questionable
shifty's Avatar
Re: frame notch
It's pretty interesting looking. Honestly, I would think the diagonal line of the rail would actually increase stabilitly and kill the need to box the frame (which is arguably not necessary anyway). If it was a true criss-cross ( X ) rather than just an angle ( \ ), I think that could be pretty sweet and even stronger than the rest of the frame.
