Old 01-31-2008, 02:58 AM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
ethenol gas ?
THe gas in my area now contains 10% ethenol. I have heard it can break up rust in the gas tank. Has anyone had probs with it in a gas tank that has been sealed?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 01-31-2008, 03:13 AM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: ethenol gas ?
Being an alcohol it is not so bad regarding rust as it drives water out preventing rust.
Driving the water out the first time may cause some issues.
Addtionaly one needs to be careful with the seals for the sending unit, carb, and fuel lines to make sure they are all compatable.
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-31-2008, 04:10 AM   #3
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: ethenol gas ?
With 10% you'll be fine, it's pretty much all I run in my 70 with no changes to the fuel system (Cheapest gas). You will get slightly less mileage.
I also run it in the winter in my car to keep water out of the fuel (currently -13F w/c -42) and prevent ice up.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 01-31-2008, 04:13 AM   #4
Jim_PA
Re: ethenol gas ?
Everyone will have ethanol in the gas eventually.
Jim_PA is offline   Reply With Quote
Old 01-31-2008, 04:18 AM   #5
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: ethenol gas ?
My concern is will it eat the stuff that was used to line the gas tank.
Old 01-31-2008, 08:08 AM   #6
lowrollin70gmc
Too many projects
Re: ethenol gas ?
I don't think it will, my truck was in a field for 10 years and I ran 10% blend in the stock tank for 2 years before switching to a fuel cell. Ever added HEET to your gas? It's ethanol and doesn't eat the crud.
Andrew
Old 01-31-2008, 11:14 AM   #7
oldsmobilekindofguy
Re: ethenol gas ?
I have ran my 1970 delta on 10% all the time it will not effect anything except a very slight decreacse in gas mileage. Ethonal burns cleaner and will actually clean the varnish out,
I live up here in SD were you can get E85 and I am lookng at going to lake area for auto tech and they had a mid 90s suburban non flex fuel and the guy worked at an ethanol plant and wanted to run E85 in his car so just ran it till the vehicle hit 100,000 mile and then donated it to the college so they could take it apart and inspect it,
There wasn't anything wrong with it it met all standards for measurements and whatnot.
1967 c-10 longbox project, check it out in projects
1969 c-10 parts pickup, twisted frame
Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block
oldsmobilekindofguy is offline   Reply With Quote
Old 01-31-2008, 12:24 PM   #8
Mudder
Mudder's Avatar
Re: ethenol gas ?
I've ben runnning it for 25 years and never have had a problem with it. I actaully prefer it over regular since it is a higher octane.
Mudder is offline   Reply With Quote
Old 01-31-2008, 12:27 PM   #9
71swb4x4
71swb4x4's Avatar
Re: ethenol gas ?
I have run it for 16+ years without a problem.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-31-2008, 01:03 PM   #10
st1x10
st1x10's Avatar
Re: ethenol gas ?
I believe all gas for the winter atleast contains atleast 10% should not do any damage.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 01-31-2008, 01:05 PM   #11
wibilly
wibilly's Avatar
Re: ethenol gas ?
i didn't know you could get fuel without ethonol. all pumps around here say it contains up to 10 percent ethonol and have fora long time
common sense isn't so common anymore
wibilly is offline   Reply With Quote
