electronic distributor
I just put a electronic distributor in my 1970 c10 in a 307 small block engine i have one wire coming from the distributor can anyone please help me with the wiring.
Re: electronic distributor
The one wire should be plugged in the under the cover that is marked B. It hooks to the pink wire in back of the ign. switch. Use 12 gauge wire. There should be a harness with 4 wires coming out the side of the dist. that plugs in in back of that single wire. The term marked T is for tachometer or testing purposes.
good info thanks alot.
ColoradoMelons.com Last edited by BigJackDaddy; 08-12-2009 at 11:28 PM. Reason: Image URL Changed |
