Old 01-31-2008, 06:37 AM   #1
Sickboy73
Sickboy73's Avatar
3/4 ton to 1/2 ton Control Arms and Coil Springs
I want to know if I can use 1/2 ton Upper and Lower Control Arms and coil springs with a 3/4 ton Spindle? I have a 3/4 Ton 2WD 87 GMC Burban that has somekind of 3" lift (this is how I bought it), but the ride is a bit rough. Every bump I hit feels like my suspension is going to break. I go a lot to Baja and the roads are pretty rough out there. I wanted to install a Fabtech long travel suspension kit, but they only have them for 1/2 ton trucks/suv's.
Sickboy73 is offline   Reply With Quote
Old 01-31-2008, 02:40 PM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: 3/4 ton to 1/2 ton Control Arms and Coil Springs
Upper control arms are the same and the upper ball joints simply bolt into them. Unfortunately the same cannot be said for the lower control arms as the LBJ's (Lower Ball Joints) are pressed in and are of 2 different diameters on their mounting surface.
Also the taper on the stems are smaller in diameter for the 1/2 ton as opposed to the 3/4 ton.Springs will be interchangeible but not the spindles.
the only way i can see to do it would be to have the 1/2 ton spindles machined to fit the 3/4 ton ball joints. Just make sure there's plenty of "meat" to ream them out without risking weakening them.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-01-2008, 01:02 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
BLE what about tire rod ends? Will they be the same as well?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-01-2008, 03:24 AM   #4
BLE 'BURBAN
I think so but let me verify before commiting to that.
Old 02-01-2008, 03:32 AM   #5
BLE 'BURBAN
Update...........
That is an afirmative. The tie rod ends are interchangable between the 1/2 & 3/4 tons.
Old 02-05-2008, 06:55 PM   #6
Sickboy73
Sickboy73's Avatar
So if I replace the springs only will this soften up the ride? I don't want to switch out my spindles because I want to keep the wheels I have. Another thing is there a way to rig the stock A-arms to do a dual shock set up. If so how would I go about making it happen?
Old 02-06-2008, 12:24 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
I'm going to move this to the 4wd section. I realize this is a 2wd, but I think you will get a better response there for what you are trying to do.
Articles-
"Refining Sierra"
