![]() Join Date: Mar 2007
sm465 swap to a nv4500
How expensive is this? Does it really require a new bell housing? I would like to have a overdrive in my 72 k5. If to much ill just pull the 465 and freshen it up.
Re: sm465 swap to a nv4500
from around 2500 to 3500 depending on were you get the parts. 1500 for trans and bell housing 500 for the round blt patern np205 or I think 800 for the advance adaptor kit to add it to a fiure 8 style then 250 for the hydrolic cluch kit then im guessing 150 for the cluch. you could aways use a 208 transfer case from a m1008 if you dont mind not using the np205 to save some cash.
Bell housing some poeple have trouble with the pasenger side clutch fork and cylinder geting in the way oof the drive line some dont if you dont have a lot of lift it may get in the way of the front drive shaft so you would need the advance adaptors bell with driver side cluch fork.
Earl 68 2500 4x4 GMC Burb |
Check out Advance Adapter's Ranger Overdrive. It bolts between the stock bellhousing and the tranny itself, and is a bit cheaper.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
![]() Join Date: Feb 2007
i used an AA bellhousing that allowed me to use my mechanical clutch, and i purchased a custom TC casing that bolted directly to the NV4500 tailhousing which eliminated both the need for an adapter as well a female coupler. i've read responses from others how time consuming and arguous setting up a custom hydraulic clutch can be, and i'm sure they have there benefits, however i haven't had any problems with my mechanical set up and it was pretty straight forward. just bolting on an overdrive unit would probably be cheaper over a 5 speed swap, but the NV4500's sychronized gears, spacing and OD over the SM465 are worth the extra $$ imo.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
It might be worth checking into a gear vendor overdrive.
Drivetrain.com |
Everything is work in progress
![]() Join Date: Apr 2006
I put a NV4500 in my truck. couple of things to look for.
Get a NV for a chevy not dodge. the early NV's had a lower first gear, but problems with 4th or 5th gear. You can use a chevy bellhousing made for the NV but the throwout fork is on the pass side and can hit the front driveshaft. And I believe it needs a round 205 to bolt up. Your stock clutch should work 1-1/8" 10 spline. Hyd clutch is easy $30 from the bone yard. If your going to use a figure 8 205 you to have/find one with the big bearing input shaft (32 spline female) I know one set up for a th400 will work. You'll also need to remount the 205 shifter. AA makes the mount. Depending on your rig you might need driveshaft work. Price of a NV4500 $1,500 Bellhousing & hardware $1,000 Driveshaft & misc. $1,000 clicking into 5th on the highway and watching the tech drop to below 3, grand PRICELESS!!
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome Last edited by cobinder; 02-02-2008 at 10:31 PM. |
