Old 02-01-2008, 12:09 AM   #1
TonyJohnson
TonyJohnson's Avatar
Filler tube questions
The end of my filler tube is chewed up and I'm replacing it with one I'm picking up here on the board. http://67-72chevytrucks.com/vboard/s...d.php?t=276549
It shows some rust inside the neck that I want to clean out. I thought about pulling the rubber stuff off and having it sandblasted, but now I'm thinking about using a drill and wire wheel. Any ideas what to coat/paint the inside with to stop rust but not react to the gas? I don't really want to go to the expense of having it plated or powdercoated, but I also don't want it rusting again... Does anyone know how POR reacts to gas? Ideas?
Thanks, Tony
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 02-01-2008, 03:02 PM   #2
TonyJohnson
Re: Filler tube questions
Ideas?
Tony Johnson
Old 02-01-2008, 07:48 PM   #3
JimKshortstep4x4
Eastwood has the gas tank material for coating the inside of a tank which should work well. I would also try your local radiator shop to see if they will coat the inside for a nominal price.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 02-01-2008, 09:16 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Try using the Glyptol, that Eastwood sells for coating the inside of engines.
piecesparts is offline   Reply With Quote
Old 02-01-2008, 10:28 PM   #5
TonyJohnson
Great ideas, guys. I should have thought of Eastwood... Now where did I see that radiator shop..?
Tony Johnson
