Old 10-20-2002, 03:44 PM   #1
dmec
dmec's Avatar
picture of power window unit
got these from a 92 dodge van. havent started install yet but i thought i would pass it on. the regulator is cable and the drive unit is flexible and can be moved around to make install pretty easy.
dmec is offline   Reply With Quote
Old 10-20-2002, 03:52 PM   #2
Zkast
Zkast's Avatar
Let us know how this works out....
One area of caution though. These units are particulary weak in the upper cable slide. Make sure your window slides VERY easily before using this type.
Zkast is offline   Reply With Quote
Old 10-21-2002, 04:34 AM   #3
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
I've got GM belt drives in my trucks, but was impressed with the siimplicity of the dodge units, and the high speed, but the owner of the van said that they have had to be fixed more than once. FYI, the lifting point should be way towards the rear of the door, maybe only 3" in from the back of the glass. Otherwise it may bind.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
