Sofa King. We, Todd, Ed.
Tow Rig Opinion?
Its obvious that its time for me to step-up and get a car trailer for hauling the Blazer as its getting to be more "off-road only". What I'm wondering is if my 71 Chevy 1-ton Van would be OK for the job? Im not worried about power (that can be "upgraded") , I'm more curious if the standard wheel base van would be heavy/stable enough to tow such a heavy load. Ironically the only towing I've done is using my Blazer as the tow rig. Any input would be appreciated. Thanks,
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
Junior Member
Re: Tow Rig Opinion?
DDDDDDUUUUUUAAAAAAALLLLLLLLYYYYYYYYY!!!!!!
#3 | |
Bloo
any pics of the van? the one ton should be fine, as long as the camper body isnt too heavy to begin with (reason i asked for pics- to see the camper). i have hauled 7-8 tons behind my 89 light duty K2500 multiple times. a dually doesnt become a requirment untill you get into a huge amount of weight in my opinion. between my 89, and my dads 94 dually, the ONLY difference i see in towing, is the diesel in his truck versus my worn out 350
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
One of the main factors is going to be the trailer you have. If you have or get only a 7K trailer, two 2.5K axels, then your van will do most the work. Save up and get a 10K trailer, two 5.2K axels, then your van will handle the load no problem. You may want to get some rear airbags just to help keep your load level, if your van sags in the back at all. And a brake controller for the trailer bakes.
Other than that as long as the van is a good runner you should be fine ![]()
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
I do everything twice, so what
Location: To the Right. One may go as far to say WAY to the Right
Blue_71
Your talking about pull'n goosenecks. I'd guess that be a little hard w/ a van
www.hilbillytruckpulling.com |
This is the only picture I have right now. The van is currently buried under 3 feet of snow. Its the green hi-top van. The blue van was just a motor donor for another project.
I have a line on a late 70's one-ton dually 4x4, but I dont want to take on another project, not to mention I already have too many rigs in my "fleet". Thanks for the trailer advice, Burt. Good to know. Once I get a trailer I will use the van for now and see how it does. I might be crazy but if it all works out I might try to convert the van to 4x4??
If you convert the van to 4x4 you will have the same problem all over again lol.
-Lincoln 1987 GMC S15 (soon to be a chevy clone) ![]() 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. ![]() Spoken by Cletus the hillbilly I like stickers... a whole bunch. |
#8 | |
Bloo
good point hilbilly
your van shouldn't have any problem pulling that load, make sure the rear brakes are adjusted properly.
Tongue weight would be your major concern, too much or too little will cause problems. drive smoothly, use 4 or more straps, crossing the rear ones to stablize the load, cross your safety chains between the van and trailer, if something comes apart the chains would cradle the tongue and put a trans cooler on the van the rest is common sense! |
Everything is work in progress
![]() Join Date: Apr 2006
Yeah what qksilver said.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
Blue, i agree.
I also only pull goosenecks, you could'nt give a bumper hitch car trailer after the last 5 years of only hook'n up to a gooseneck. My only suggesion is get a trailer that is as low to the ground as possiable.
Thanks everyone, I've easily doubled what I thought I knew about towing from all the suggestions.
#13 | |
Bloo
defintly true on the low to the ground, that trailer hooked up to my truck is a pain in the butt to get a vehicle or tractor on! if i ever buy a trailer of my own it'll defintly be low.
i also agree on the gooseneck, i hate hauling anything pulled by the bumper now ![]()
#14 |
In a year of daily towing a 5000LB roller on mountain roads to and from job sites, I never once wished for a dually. The big block truck made a better job of it than the small block. Unless your trailer is really a monster, the '71 should do fine.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
#15 |
x2 on the 10K trailer thing.
When I dumped the 7K 16ft trailer for the 10K 18ft trailer, that alone made a big difference. Tandem trailer brakes are a must as well. Tires on the tow rig will make a huge difference too, go 10ply and never look back. Another great mod/addition is a load leveler system, a 4-way torque control set up makes for an easier, more controlled tow. The van will do fine but just make sure the ass end is up to the task. Last edited by vtblazer; 02-04-2008 at 10:22 PM. |
