Old 02-01-2008, 10:18 AM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I Like Shiny Things, Coated intake/Headers
I thought I would show some pics of my freshly coated headers, intake & water neck.
The water neck is a stock gm unit, intake is an Edelbrock RPM and the headers who knows.
These are coated with a product called Armor Coat at Aesthetic Finishers in Piqua Ohio.
The finish is good to 1350 degrees, it is a ceramic based product.
I like the fact that it is supposed to reduce under hood temperatures.
The heat shield properties should help reduce the intake temp since the coat everything inside and out, top and bottom.
I did learn one lesson. The smoother the base finish of your product the smoother the resulting coating. I had no idea the headers had any pitting. Well I can see the pits now. They can also do the headers in black which would hide the pits better.
All in all I am very happy with the results, it should add a nice bit of shiny under my hood
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 02-01-2008, 12:14 PM   #2
john@thepier
john@thepier's Avatar
Re: I Like Shiny Things, Coated intake/Headers
Looks good and once there on and your going down the road with a smile on from ear to ear, you'll forget about any pits in the finish. John
john@thepier is offline   Reply With Quote
Old 02-01-2008, 11:13 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Looks real good, will be interested in seeing how it holds up.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-02-2008, 12:07 AM   #4
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
How's the Pricing on the Header's, Can u PM me Contact Info for them................
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 02-02-2008, 12:52 AM   #5
stanglifemike
stanglifemike's Avatar
Looks really good, I'm also interested in how much $.
71 C-10
98 Mustang GT
06 Mustang GT
stanglifemike is offline   Reply With Quote
Old 02-02-2008, 02:52 AM   #6
70c10
67-72 Addict!
70c10's Avatar
They turned out great!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 02-02-2008, 04:06 AM   #7
69halfton
69halfton's Avatar
lookin' good
got the same thing done to mine, same sort of grey, but i got them in mate finish. and i sandblasted the headers first, so it looks decent.
the intake got that endurashine stuff from edelbrock. also an rpm intake.
man i hate polishing.
really makes the engine compart look good, on both trucks.
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 02-02-2008, 04:07 AM   #8
69halfton
69halfton's Avatar
...i thought you could see more of the headers in that picture...
- Jason
Favorite caption:
Old 02-02-2008, 04:10 AM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin' good, looks like money well spent!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-02-2008, 10:26 AM   #10
1968SWBBigBlock
Active Member
The Intake was $135, air gap intakes are $165.00
The headers $220.00 I think.
This process sprays on wet unlike powder, and goes thru a ceramic coating process for the thermal properties.
Greg demos this stuff by banging 2 pipes together until they dent. No chips or cracks.
Aesthetic Finishers handles all the prep work.
Everything goes into an oven to be baked 1st in an oven big enough to fit an entire car or truck, after it comes out of the oven the product is scotch brited, then plasted with plastic beads custom ground in house or alum oxide depending upon the material they are blasting.
After blasting they go thru a multistep chemical cleaning process.
They are then sprayed, treated to ceramic, baked and finally hand polished.
I am told the only care I will need to give these will be a polish once a year with blue magic metal polish.
The coating will not stain with fuel which I really like.
The finish is quite slick to the touch so it should be very easy to clean.
These guys are nice to work with, they are all car guys.
They have two parts to the business. One is a production powder coat business and the other is called the motorsports div.
Greg who runs the motorsports div is doing a frame off resto on a 64 vette convert. that he bought when he was in high school.
When I picked up my stuff they had several stock car, sprint car chassis' in house, an entire VW floor board, and a 32 ford roadster. All other customers rides
I wonder if I could do my whole truck
1968 SWB
Old 02-02-2008, 10:43 AM   #11
cory321
Problem Child
cory321's Avatar
I'll have to check them out their not too far from me
1972 gmc sierra grande
350/350 a/c soon`to get a new 350
I Survived Norwood
cory321 is offline   Reply With Quote
