Old 02-02-2008, 12:02 AM   #1
chopper tom
52 vac wind shield wippers???
can some one tell me how to get my vac wippers working again on my 52 chevy truck ?Has any one ever took one apart and tryed to fix it before ?
I cant aford an electric one right now ,and i know that i can use it on a v-8 becase my old 49 coupe used to work good with one .
I been told to put oil in it ,but where and what kind of oil????
chopper tom is offline   Reply With Quote
Old 02-07-2008, 06:26 PM   #2
BigJackDaddy
BigJackDaddy's Avatar
Re: 52 vac wind shield wippers???
I haven't had the "opportunity" to rebuild one yet since mine are still working...
whish, psssh, stutter, swish
I've heard that this guy will not only redo them for $79 (I know, I know) but also sells parts if you end up needing them.
Whish I could be more help.
ColoradoMelons.com
BigJackDaddy is offline   Reply With Quote
Old 02-08-2008, 12:33 PM   #3
chopper tom
Thanks man ,every little bit helps!!!
Old 02-08-2008, 11:31 PM   #4
robin58
Just a thought, if you are thinking about converting to electric, you don't have to go with one of those relatively expensive kits. There are several other methods to get away cheaper. I'll see if I can locate the article, but there was an article a few years back in one of the magazines about putting a Toyota wipermotor in. Also, it is relatively simple to use a cheap boat windshield wiper motor.
robin58 is offline   Reply With Quote
Old 02-09-2008, 12:46 AM   #5
chopper tom
I would love to see that artical if you can find it!!!
Old 02-09-2008, 01:31 AM   #6
robin58
Looked through all my old magazines and can't find it. But this is basically the same idea:
http://www.hotrodsandhemis.com/updateDec.html
Old 02-09-2008, 01:56 AM   #7
robin58
Or like I said, if you want to go cheap use something like this:
boat wiper motor"
or
eBay
You'll have to do some fabbing of some brackets and as long as you don't mind the wipers not wiping "butterfly style" a little ingenuity will make that one of the cheapest ways.
That first listing is for a 110 degree sweep. You can also find them in a 80 degree sweep which probably would be a better option.
Old 02-09-2008, 03:50 PM   #8
55dude
55dude's Avatar
leave it mounted and just use rain-x. the vacuum wipers are junk and rain-x is less than $10. they also have a product if your defrost system doesn't work for the inside of the windshield.
55dude is offline   Reply With Quote
Old 02-10-2008, 02:25 AM   #9
1-ton of fun
polishing a turd
1-ton of fun's Avatar
that's called fog-x. works pretty well, i had a 55 bel air that the heat/defrost didn't work, and the fog-x worked pretty good for me
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 02-15-2008, 07:44 AM   #10
BigJackDaddy
Originally Posted by 55dude View Post
leave it mounted and just use rain-x. the vacuum wipers are junk <snip>.
Some of us prefer "nostalgic"
ColoradoMelons.com
Old 02-15-2008, 11:07 PM   #11
chopper tom
I just wana drive my truck till i can aford some better wippers ,thats all .
Old 02-17-2008, 12:58 AM   #12
51chevytruck
I have had my motor apart but it has been many years ago. From what I remember it is a very simple setup. I think it was harder to remove the motor than actually fix it. The inside is simply a paddle consisting of a piece of leather sandwiched between two metal plates. The paddle arm is attached to or is the spline that your arm attaches to. I softened the leather with some Vaseline reassembled it and I have had no problems since. Don't be afraid to take it apart it is an extremely simple setup and you will have no problems.
51chevytruck is offline   Reply With Quote
Old 02-17-2008, 09:57 PM   #13
chopper tom
wow man!,finally what i wanted to know !
Thanks so much !
