Old 02-02-2008, 01:14 AM   #1
Voodooracer
Voodooracer's Avatar
New to these trucks.
Having some issues witht the headers I bought for my 67. The motor looks like it is to far forward and that is causing a lot of issues with the headers clearing the perches. My ? is, do I have the wrong perches or do I just need to break out the blue wrench, grinder and welder? I thought the first exhaust port should be on top of the perch. And mine sits in between the first two. My dist. is literally 7-8 inches from the firewall. Any help we be appreciated.
Voodooracer is offline   Reply With Quote
Old 02-02-2008, 01:32 AM   #2
uno67
uno67's Avatar
Re: New to these trucks.
most likely motor is in correct location when you put it in the 6cyl spot it goes to close to the firewall to the point you can't pull the motor till you remove the dizzy. the framerails in the 67 are wider than the 68 and up you just have to take out the grinder and get to work.
uno67 is offline   Reply With Quote
Old 02-02-2008, 01:32 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
that actually sounds about right for a small block from what I remember. (haven't had a small block truck since 04) Do you have any photos?
Old 02-02-2008, 01:38 AM   #4
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
I bought the cheapie headers from Summit Racing for my 70 w/350 and they fit with no alterations , I measured 7" from top of valve cover to firewall hope this helps.
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 02-02-2008, 03:01 AM   #5
Voodooracer
This will help alot, I'll look this evening and see what the clearance is and take a pic.
Thanx guys.
