WTB I6 motor mounts for a 4X4
Like the title says!! Are they special, or will the 2wd stuff work?? Picts of this set-up done??
Born Psycho
![]() Join Date: Feb 2001
Re: WTB I6 motor mounts for a 4X4
6 cyl cradle is different from V-8, and 2wd stuff won't work.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
![]() Join Date: Aug 2005
I have mounts, but no towers
Picts, so the whole set up is different? The mounts that I have on the motor, look like they stradle a clamshell type mount (think 72 BBC style). If so I could use a 73 and up crossmember and bolt my mounts to the clamshell style?? Picts please if you have an I6 in a 4X4 lets see picts!!
![]() Join Date: Aug 2004
Here is a engine cross member from a 67 4x4 with a v-6 no idea if it will help you or not and it is 4sale if you want it.
i have one from a 69 K10... its still in thee actully. i need a v8 one so i'll sell the one i have.
let me get some pics of it tomorrow or sat |
Do you want to swap as I have the V-8 one? LMK?
I had all those parts awhile back but I think they got hauled off for scrap....
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
Well, did you or didn't you??
They call me the Breeze...
![]() Join Date: Jul 2007
How soon do you need it??? I have one, but it's currently in my K20. I am going to pull the 250 I6 soon, and put a 350 in it and would be willing to swap for your 8cyl crossmember, depending on how soon you need it. Also I can snap some pics on Sat. if you would like, I would take some today but there is currently a ice storm happening here, LMK, Mike.
Mike 69 K20 "Beer is proof God loves us and wants us to be happy"....Ben Franklin |
ASAP I'd gladly do a swap, or buy it outright. Picts would be great. LMK!!
TTT there were some responses about folks having them but I haven't seen picts nor bought any, so if you have them and want to sell them, PLEASE reply!!
#13 |
I'll look around for the ones I had. Not sure if I scrapped 'em or not, but I think the 6cyl crossmember and towers are identical to the v8 ones. The ones I took out of a 71 Blazer looked exactly the same as the ones in my 72 (originally 350 truck).
#14 |
Weekend Warrior
I think the V8 & 250 6 are interchangable. It's the 292 that would be different, but I could be wrong. I know that I put a 250 6 on a V8 4x4 front crossmember/mounts with no problem - everything bolted up just fine.
The passenger mount on the 292 is further back or forward or something making that one non-interchangable
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 03-26-2008 at 09:48 PM. |
#15 | |
#16 |
Do you guyshave picts of the 6's in there? My motor mounts are the later style that fit over the clamshell mount. I'd guess a 73 and up style system would work or I need to get the correct L6 Motor mount? HELP, this is too confusing!!
#17 |
Weekend Warrior
What motor are you going to be running first of all??
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 03-27-2008 at 02:20 AM. |
#18 |
250
#19 |
Weekend Warrior
Use the V8 Crossmember with the I6 mounts (the rubber ones should be the same as the V8, but you'll need the metal bracket that bolts on the I6 block that the mount attaches to.)
This was an original '71 K-10 V8 truck, and had a V8 in it when I got it. I pulled it (sick) and replaced it with this good running 250. The metal brackets were on the motor as it was in a '72 truck. But the rubber mounts bolt to the brackets. It is kinda hard to see in the pictures, but maybe they will help. ![]() ![]()
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
#20 |
Yep those are different than the motor side (metal mounts) that I have. I guess I need the metal motor side of the mount, ANYBODY!?
