Old 02-02-2008, 09:40 AM   #1
pyro883
Timing
I have a quick question, when using an advanced timing light and you are just trying to check to see if you motor is running at 8 deg what deg should your timing light be on?
pyro883 is offline   Reply With Quote
Old 02-02-2008, 10:05 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Timing
If you're using a setback type timing light ,yes.You do need to remove and plug the vacuum line to the dist.Plug the side to carb or manifold.Also you may want to chek the condition of the harmonic balancer.If it's cracked or looks worn it may have slipped giving you a false reading.Someone should be able to give you more info on this.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-02-2008, 10:40 AM   #3
dadsbrew
dadsbrew's Avatar
Re: Timing
If you unplug your vacuum advance and plug it off then set your timing light to 8 your timing mark should be on 0. If not turn your distributor until it is, tighten and plug your vacuum line back up to the distributor.
1970 K-10 400CID, to much cam--not enough compression Stan's Headers and a 4" lift / 1990 R1500 Suburban 4X4, 350CID with vortec heads, edlebrock intake, TBI, 10:1 compression and Stan's Headers
"The probability of someone watching you is directly proportional to the stupidity of your actions"
dadsbrew is offline   Reply With Quote
