71 2wd 12 bolt width
I need the actual width from wheel mounting flange to wheel mounting flange. I installed one of these in my uncle's 66 GMC truck and need to go narrower to accommodate a larger tire.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Re: 71 2wd 12 bolt width
I have my eye on an 8.8 with rear disc from and exploder. I just need a stock width to reference from. I think we will probably just go with a 12 inch wheel and a drag radial. It already has been converted to trailing arms and coil overs but it has a nasty small block and a muncie!
you need to scope out the new racing section! Thanks for trying to get a measurement !
Welcome to the board from Alabama!
Anyone ever come up with a width from outer drum to outer drum?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
![]() Join Date: Aug 2003
It's 57" from inside of each backing plate,but not sure on the other measurement.
the explorer 8.8 rear is 60.25 from mounting flange to mounting flange. I bought one from a v8 mountaineer with 3.73's and a posi and 31 spline axles for 275 from the junk yard.
DJ, is that a 5x5 patern or 5x5.5?
I have a lead on a 61" drum to drum 9" for $225. I'm not sure that I want to go disk in the rear. I asked somone one E-bay that has a 73-87 6-lug 4x4 the width from drum to drum. this is what he gave me.. "measuring it by myself I came up with about 64 1/4 inches from one side to the other where the wheels would seat against the drums, and 42 inches between centers of the spring perches, thank you" Are these the same width as the 70 1/2 throuh 73 5-lug?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 Last edited by Super73; 04-21-2008 at 12:09 AM. |
