Old 10-20-2002, 09:07 PM   #1
primerbomb71
Question suspension conversion
is it possible to use the front suspension from a 86 3/4 ton on a 68 1/2 ton? i know i can use the rearend with a conversion kithas anyone ever done this before?
71 c-10 in the works
primerbomb71 is offline   Reply With Quote
Old 10-20-2002, 09:29 PM   #2
crazy longhorn
Fabricate till you "puke"
Yes, you should be able to bolt the complete crossmember from the 86 under the 68. There will be a couple bolt holes that need to be "egged out" . Good luck.....crazy longhorn
crazy longhorn is offline   Reply With Quote
Old 10-20-2002, 09:45 PM   #3
primerbomb71
what i'm wanting to do is swap out the spindles and springs. is that possible?
Old 10-20-2002, 09:57 PM   #4
crazy longhorn
To swap the spindles, you need to replace the lower a arm (diff hole size on the balljoint), all 4 balljoints, tie rods, & center link. 71 up the centerlink & tie rods are different as far as lenghts on ends & sleeves, & hole sizes in the center link. i swapped my longhorn to a 1/2 ton using mid 70s parts, but alot of the guys are just swapping the complete assy to save on the parts mix. Good luck......crazy longhorn
