Old 02-03-2008, 04:41 AM   #1
mark69k20
mark69k20's Avatar
3-speed TO 4-speed swap?????
Will a '67 4 speed that sat behind a 6 cyl be a simple bolt in behind the 307ci in my '69 currently a 3 on the column ? Besides the cutting of the floor and removing the mess of shifting rods what other problems will I face? Thanks ahead of time for the advice!
mark69k20 is offline   Reply With Quote
Old 02-03-2008, 04:54 AM   #2
tjvending
tjvending's Avatar
Re: 3-speed TO 4-speed swap?????
http://67-72chevytrucks.com/vboard/s...d.php?t=268873, see this tread I started, its has some information on the 3sp to 4sp
TJ
tjvending is offline   Reply With Quote
Old 02-03-2008, 04:58 AM   #3
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
If it's a HD 4 spd lenghts will be different and you will need high center hump ,posible spline count difference otherwise
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 02-03-2008, 07:13 AM   #4
lilred67
lilred67's Avatar
spline count is the same. depending on wheel base of the trucks being the same , whether the drive shafts will swap. i put a hd 4 speed in my swb and had to cut the ds down because it was from a lwb. easy swap, every thing is straight foward........
lilred67 is offline   Reply With Quote
Old 02-04-2008, 02:04 AM   #5
mark69k20
mark69k20's Avatar
Thanks guys I'm heading up to NY to look at this 4 speed, your help is appreciated!!
