Old 02-03-2008, 05:46 AM   #1
pyro883
Oil leak
I have a ton of oil leaking from the bottom of the engine towards front of it and I cant really see where its coming from but there is quite abit of oil leaking any ideas on what it could be?
pyro883 is offline   Reply With Quote
Old 02-03-2008, 05:49 AM   #2
cruiserman
Re: Oil leak
Front main seal.
72 C2500 LWB 402 Sierra Grande
05 Odyssey
08 Tundra
cruiserman is offline   Reply With Quote
Old 02-03-2008, 06:04 AM   #3
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
Re: Oil leak
yep
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 02-03-2008, 06:11 AM   #4
pyro883
Re: Oil leak
Originally Posted by cruiserman View Post
Front main seal.
would that me on the oil pan?
Old 02-03-2008, 07:10 AM   #5
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Re: Oil leak
Originally Posted by 60-66 Nut View Post
LOW DOUGH, you might check to be sure you are not missing the short 3/8" bolt that goes in one of the holes on the front passenger side of the block. One of these holes(I think the top one) is drilled into the crankcase directly in line with the fuel pump push rod. Some people pull that bolt out and stick a longer one in there to hold the push rod up while changing the fuel pump. I've run across a couple leaking there before. It would only leak when you drove it, not just sitting there. Just a thought.
60-66 Nut
That was my problem. Didn't have a bolt there. No more leak.
http://67-72chevytrucks.com/vboard/s...d.php?t=270212
Thank you 60-66 Nut
LOW DOUGH is offline   Reply With Quote
