Old 02-03-2008, 07:57 AM   #1
edman87
junk collector
My camaro tach cluster-done!
I finally got my cluster together! Removed gas guage, put a tach from a 86 z28 in its place. Originally the camaro tach had the oil pressure gauge in the corner, swapped it with the camaro fuel gauge. It fit with a little dremel work. Also installed a NOS clock in the vacant location. Reset the odo to 0 miles. Used the cluster from my 89 parts blazer because it has the trip odo. The knobs for the trip odo and clock are aluminum tire valve caps with the end of a sports ball inflator needle screwed in them, then drilled and tapped for a 6-32 set screw. Pics below. Whatcha think??
Pictures no longer available.
Forum Staff
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 02-03-2008, 08:03 AM   #2
chev74
Addicted to Chevy
chev74's Avatar
Re: My camaro tach cluster-done!
man, thats lookin sweet!
i like how you did the fuel gauge inside the tach
btw... how hard is it to set the odometer back to zero?
chev74 is offline   Reply With Quote
Old 02-03-2008, 08:11 AM   #3
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Looks good, I like the tach and fuel gauge..
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 02-03-2008, 09:49 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Is it just the angle, or is the tach larger than the opening?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-03-2008, 10:20 AM   #5
chev74
Addicted to Chevy
chev74's Avatar
coule be.... looks like it could be really close if not
Old 02-03-2008, 10:33 AM   #6
edman87
junk collector
The tach is identical in size to the gas gauge that came out, used 2 of the same mount holes. The bezel circle does crowd it a little bit and the angle is not a good one. The print on the tach plate is larger taround than the speedo and such because it was not recessed nearly as much in the camaro.
As to the odo, it was pretty easy, but hard to explain, you really just take it apart far enough to get the number reel out and move the keeper on the end of the rod enough to make a small gap between the reels, then move them around to where you want them and push the keeper back to where it was and re-assemble.
Thanks for the comments, if I xcan just find the time to put the blazer back together enough to drive so I can look at the gauges, I will be fine.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 02-03-2008, 12:23 PM   #7
beaterC10
Man that is slick. I was looking at camaro clusters on ebay. I saw several that looked like the tach was driven by a VSS connection from the speedo. The connection to the tach looked like it was part of the printed circuit board. Are all of them like that?
My quick peek at ebay looks like 82-89 are the correct years with your choice of 85, 110, or 145 mph speedos. Do you know what the differences are in the different years. I have always hated camaros, so I never paid any attention to them.
beaterC10 is offline   Reply With Quote
Old 02-03-2008, 08:40 PM   #8
DBLSPRT68
DBLSPRT68's Avatar
That looks great!
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 02-04-2008, 01:32 AM   #9
cochino12
It followed me home?
cochino12's Avatar
Looks good man
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 02-04-2008, 01:33 AM   #10
edman87
junk collector
The tach board is labeled on the back for ground, 12v and dist. Would have to get the 1 from a v8 car unless you wanted to mod the resistor chip in the driver board. The 85mph clusters are usually fairly cheap, and 82-89 should be the same. I used this 1 just because I have a 86 z28 parts car and it was right there in my face. Also have the old cluster from my 91 camaro, but the tach shape is way off and a very different design. The 82-89 are metal plates just like the other gauges in 73-87/91 trucks.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 02-04-2008, 02:59 AM   #11
Malo83
Cruzzzn' Vet
Malo83's Avatar
Now that's what i'm talking about
Malo83 is offline   Reply With Quote
Old 02-04-2008, 04:18 PM   #12
Pyrotechnic
Pyrotechnic's Avatar
Looks sweet! Can we get some in truck and drivers view shots when you get it installed ?
Pyrotechnic is offline   Reply With Quote
Old 02-05-2008, 02:38 AM   #13
edman87
junk collector
Will do, but the k5 is a ways from being complete and there is nothing inside it that is not metal right now.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 02-05-2008, 03:18 AM   #14
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I like it alot. Thats awesome.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 02-27-2008, 11:27 AM   #15
rfmaster
rfmaster's Avatar
Edman87
Thanks for posting your work, which got me inspired to do the same. So, last weekend I managed to pull a Tachometer and fuel gauge from '85 (at least that's what JY markings were) Camaro, not a Z28, but V8 car. I took some side by side photos with my '75 fuel gauge.
Questions
1) There are no visible markings on the PCB indicating which post is what (12volt, grounds, tach) - do you have schematic for that PCB?
2) How did you get fuel gauge in place of oil pressure??
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 02-27-2008, 08:28 PM   #16
jchav62
1962 C-10
jchav62's Avatar
Nice!! That looks SICK!!!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 02-28-2008, 09:50 AM   #17
SBTork
Garage wrench
SBTork's Avatar
wow, you may have started something. The z28 tach looks right at home in the stock cluster, very very good work.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 02-28-2008, 11:54 AM   #18
84 400
Sb 400 club
84 400's Avatar
like it man looks really slick
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 02-28-2008, 10:20 PM   #19
Frosty
Under desk
Frosty's Avatar
I read this yesterday and was still thinking about it today. Very cool idea! Good job.
Frosty Smith 1979 GMC 1/2 ton 2wd diesel that now has a 1976 Firebird V8 engine and is a 4X4 with a 7inch lift.
The real question is would I have still bought it if I had known all this...
Frosty is offline   Reply With Quote
Old 02-28-2008, 11:22 PM   #20
edman87
junk collector
I knew I was supposed to do somthing else when i took it back apart to paint the inside of the cluster in chrome! I will pull it back apart and get some pics with notes on what and how I did it asap.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 02-28-2008, 11:23 PM   #21
edman87
junk collector
The board on the tach is marked, just not in the right places. I will add informative info in a while.
Can anyone tell me how you draw on the photos with the comp? to point out somthing
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 02-28-2008, 11:52 PM   #22
Mickey_D
Dirteh Kitteh
Mickey_D's Avatar
Use a text box (red arrow) in Paint.
Just make sure the overlay setting is selected (blue arrow).
Darrin
1955 Willys CJ-5 all original and the oldest CJ-5 on the road.
2001 Dodge Neon (wife's car)
1995 Jeep Grand Cherokee Limited Edition SOLD
1981 K15 Custom Deluxe 4X4, rusty but trusty wood hauler. SOLD
1993 S-10 4X4 Tahoe SOLD
Sign up with the Contact List
RIP ESLL
Mickey_D is offline   Reply With Quote
Old 02-29-2008, 01:13 AM   #23
edman87
junk collector
I know about paint. How do I get things from paint to this board? I use photobucket to post pics normally. I will try it out.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 02-29-2008, 01:59 AM   #24
edman87
junk collector
OK, took the cluster apart for hopefully the last time- had to do it anyway because I ran the wires through the wrong hole.
Here is a few pics and a wiring diagram I drew trying to explain what I did. Notching out the tach plate and gas gauge plate to match up is up to the next person. I used a dremel and pliers to flatten the gas gauge face and fit it to the tach face. I could do a lot better job if I did it again, but it is all hidden anyway. The tach circuit board has to be notched a little bit on the side to accomidate the gas gauge. The truck cluster has to be notched out where the bottom of the new setup will rest. For all of the wiring hookups except the tach signal wire, I tied to the original fuel gauge tabs. I did this by grinding the front lip partly off and using a bolt and nut to attach the new wires to the tabs. After all 3 of the wires are connected, cover the inside part of the tabs and wires wit a couple layers of electrical tape to be safe.
Also, the gas gauge is using 2 of the original oil pressure gauge holes in the tach board, but they serve no purpose other than to hold the gas gauge in place. I used a razor blade to remove some of the circuit metal on the board to keep it from contacting the new gas gauge terminals.
Here is the pics, I hope this all makes more sense with pics. I am sure O have left somthing out, so ask if you need more explanation.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 02-29-2008, 02:00 AM   #25
edman87
junk collector
OK, the diagram- last pic, didn't come out big enough to read. I will try and fix it.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
